What does Ford think the Maverick is for?
oldgeek
1,027
USA
Ranger XLT
I used to be hopeful looking under the hood of trucks. Always hoped that the engine would be so easy to work on, but they still cram half the engine under the dash.
A customer always buys Chevys and has a HD. He complained that the cabin is pushed forward so his left foot is resting on the fender well. Says it's uncomfortable.
ekrampitzjr
1,050
Virginia
I think it has to do with the US adopting the europeon style pedestrian crash standards
That was it exactly. All the pickups have high front ends now, even the smaller ones. I can't figure out how mowing down pedestrians you can't see because of a tall front end helps their safety.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
1.5” till I get these springs replaced
225-70-R14
What standard is this? A truck's hood is taller than a Civic's roof. A Miata has to look up to see the top of the wheel well. I can't imagine the weight difference making a huge difference in injury.
rusty ol ranger
Im a Jeep guy now.
7,411
Michigan
177 CID
I dont know the specfics but it has something to do with energy absorption when smoking a jaywalker.
Big tall plastic grills with nothing behind them evidently do it better then chrome bumpers and steel hoods
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
639
Central Indiana
The US actually has no pedestrian safety standards. Instead of implementing standards for pedestrian safety, the NHTSA chooses to educate pedestrians on how not to get run over:
And big trucks aren't sold in any meaningful numbers anywhere else in the world that would have standards that influence their design.
The styling of trucks has a lot to do with marketing and image as well as massive capability. If you want to have rated payload capacity over 2k lbs in a half ton truck then you need to have suspension travel. If you want massive towing capacity, then you need lots of frontal area for bigger heat exchangers. So there's some amount of justification for larger, taller trucks but so much of it is just about making buyers feel more macho.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
These old rams can make 600ft-lbs easy. Plenty of airflow with a bellybutton-height hood. I'd say 100% marketing then.
1995-dodge-ram-3500-59-cummins-diesel-5-speed-manual-108k-miles-12-valve-7-3397618066.jpg
rusty ol ranger
Im a Jeep guy now.
7,411
Michigan
177 CID
I dont so much buy the more cooling. Yes obviously theres more capacity for that but plenty of old trucks could haul 2k+ usually with massive iron blocked big blocks and overheating usually wasnt an issue unless under extreme circumatances.
Roert42
4,941
Kintersville, PA
Ranger XLT
4.0 SOHC
Smaller engines running at higher RPMS with twin turbos must generate a lot more heat. I can't imagine how they wouldn't.
snoranger
Professional money waster
ASE Certified Tech
13,599
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Personally i wish i could find a clean 6.9 bullnose with a 4sp for a decent price
You really do love your underpowered, leaking Fords. (<—That’s a 2.9l insult too.) The 6.9l was probably the worst engine available in an F250/350 back then. I’d rather have a 300.
The best place to find a 6.9l bullnose is in the right lane, going about 6mph, struggling to get out of its own way. Just follow the trail of oil and black soot cloud… they both lead to a 6.9l
stmitch
MTOTM Winner
639
Central Indiana
The last year for that bodystyle truck was 1998, and with the Cummins it was rated at 235hp/460 ft-lbs. It had a max tow rating of 13k in the right configuration.
Here's a cool old Motorweek review of 3500 trucks from this era for reference (note the built in step on the Ford cab and the tow ratings that could be outdone by some new half tons):
Payload stresses frame and suspension. Towing stresses the drivetrain. You need more cooling now because they tow a massive amount more now.
The modern version of that truck in your photo can be equipped to tow over 37k lbs, and they have a pretty rigorous standardized towing test now (which was only adopted for 2013 model year):
So if you're designing a truck, and you know it needs to tow and haul and have some amount of off road capability, then you get what we currently have. They could definitely be less butch, but comparing an old truck that would really struggle to complete J2807 with it's much lower tow rating to a brand new truck with insane capability is kind of silly.
rusty ol ranger
Im a Jeep guy now.
7,411
Michigan
177 CID
What? The 6.9 was a damn good engine. Yes they make roughly the same power as a 351W but get better MPG, and they sound bad ass under load.
Obviously a step down powerwise from my 460...but most things are.
stmitch
MTOTM Winner
639
Central Indiana
This is the front of a new F350. It has an AC condenser (black) and 2 radiators (1 that fits under the core support and one that stands taller behind the core support) :
The secondary radiator is for accessories and the Charge Air Cooler and gets sandwiched between the black AC condenser and the primary engine radiator:
J2807 is no joke. Putting an old HD/3500 level truck through the same certification process as a brand new one would lead to those old trucks having tow ratings that modern half tons would be embarrassed by. If they were able to finish at all.
rusty ol ranger
Im a Jeep guy now.
7,411
Michigan
177 CID
This is the front of a new F350:
And there's a secondary radiator for the accessories too (sandwiched between the black AC condenser and the primary radiator):
I will agree to disagree
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
All I can comment on is the 5.9 Cummins in that body style Ram. The engine is not the weak point for towing. It’s mainly from the tranny back that’s weak, then the tranny. The 5.9 came from the factory suuuuper underpowered… but that’s why it can make 500k miles easy. It does have issues with exhaust gas getting too hot. That’s probably the weak point with it but I have zero other diesel experience
17,756
SW Iowa
