WHAT DID YOU DO TO YOUR RANGER TODAY?
rusty ol ranger
2.9L Mafia-Don
814
Michigan
2.9L
Today, I repacked the front wheel bearings and I replaced the brake pads and discs. Mainly because I only had 1/32" of pad material left! :oops:
Meh. Steel on steel stops just fine.
I once ran a set grinding so long that it wore the rotor to the fins, then overextended the caliper and i lost my brakes as i careened torward a T intersection at 50mph.
Good thing i had a 4speed :)
Rock Auto 5% Discount Code: 173A8B749AB83C Expires: January 1, 2020
Forum Moderator
1,425
SW Iowa
Hopefully dealt with a few coolant seeps (heater hose and lower radiator hose) did some scouting for a later front sway bar and did a little offroad tweaking to the carb (plugged up the passage between the two bowls with a piece of fuel line) I also picked up a fuel pressure regulator so I can turn down the pressure when offroading which is supposed to help but I need a close nipple to combine that with the fuel pressure gauge I already have so that was a swing and a miss today.
Uncle Gump
Well-known member
696
Plano IL
Lead, Follow or get out of my way
Having been Off Road with carburetors for many years... I've found that lowering fuel pressure will indeed help... at least when used in combination with tweaking the floats a bit. The float tweaks would include dropping the float "level" as far as possible without affecting the circuitry and not starving the engine at WOT. Then I would tighten the distance between float "level" and float "drop" considerably... this helps prevent float bounce in the rough stuff... and lessens the distance the needle travels in the seat which helps prevent the needle sticking in the seat and with uphill/downhill situations. Once I found the sweet spot between fuel pressure and float adjustments... I just ran those settings all the time. No need to adjust fuel pressure for on or off road use.
91stranger
Well-known member
185
ohio
FORD
I was hard on mine this weekend. Went to an auction with my trailer and left loaded to the bone. Got a killer deal on a lot of 5 gal buckets of new unopened drywall mud, mortar filler, and barn paint for $2. Putting eight 5 gal buckets on the front of the trailer made it very tongue heavy and I did not spread the load very evenly as I was rushed to get loaded and wasn't sure if everything would fit. Seemed like the drive home (1hr 10 min) was all really LONG slow inclines and my truck was struggling just to stay at the speed limits. It's was weird b/c when I came to a stop the oil pressure gauge would flicker like crazy but would go back to normal when I got on the gas. I just changed the camshaft synchro and the oil pressure sender (with a cheap o'reilly's brand which was my mistake and I plan on going back to the original bc I don't think it was bad). so hopefully the truck was just struggling with the heavy/awkward load. Great day but tiring after only 3 hrs of sleep.
Forum Moderator
1,425
SW Iowa
I am more worried about off camber stuff. The only time I got it mess up on rough ground is when I hit a area of plowed ground too fast to drive on anyway.
The thing runs good enough I dont want to play with the floats unless I have to.
8thTon
Active member
215
Pennsylvania
I drove it to work, and everything worked so well that I stopped listening for problems and put on some music.
black_demon69
Well-known member
47
AZ
1993 & 1994
2.3l & 4.0l
Installed a light bar
Well-known member
1,332
I think I scored an E-fan, but I probably won't get it in my hands for a month or two.
Forum Moderator
1,425
SW Iowa
Bird76Mojo
Well-known member
925
nunya
I used my 2001 4x4 to drag a very large (on fire) tree out of the field after dad's Allis 185 with loader got stuck. Then I pulled his tractor out. The tree was hollow and I had packed it full of sticks and lit it on fire. It was howling like an industrial chimney with fire shooting 10+ft out of the top. It fell over, caught a little of the field (corn) trash on fire, so he had attempted to move it with his tractor, but the Allis was too heavy and sunk like a rock.
So I guess what I did to my Ranger today was get it muddy..
Then I went to check the brush fires a while later in my 87 V8 truck and whipped a 180 in the middle of the road because I felt like it.
Well-known member
1,332
Bird76Mojo
Well-known member
925
nunya
Shipping it shouldn't be that expensive with a size of around 15"x17" but adding the shrouding might increase that size a little.. Regardless, for a $300 (free) fan it's very worth it. I almost claimed it the minute he posted it but I want to stick with a mechanical fan.
Well-known member
1,332
Right, shipping shouldn't be much. But my sister lives in Co Springs where the fan is, my cousin is moving to AZ, and most of the rest of our family lives here in the same town as I do. I just gotta make sure nobody is driving through there to here before I pay to ship it.
Saddle Tramp
54
Florida
Not today but I sanded off some surface rust in the gutter rails and repainted them over the weekend.
