WHAT DID YOU DO TO YOUR RANGER TODAY?
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
Saddle Tramp
Active member
97
Florida
Took another old mower in for repairs.
sgtsandman
Well-known member
787
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
snoranger
This page left blank intentionally
ASE Certified Tech
1,408
Jackson, NJ
'79,'94,'02,'17
All Fords
Really? For that one? I have the 2.9l is greater than the 3.0l...
That’s it, I’m getting you this for Christmas:
33657
I was going to tell you where to find your next Ranger engine, but not anymore:
33658
PacificGreen1998
Active member
90
Eustis Florida
3.0l Vulcan v6 with low miles...
stock since 1998
That one guy with ADHD and doesn't stop talking about cars.
Still having issues with the rear end. I think the pinion nut is loose. I "thought" I had marked the pinion nut and flange before I took it off but the damn marker (Milwaukee Inkzall which supposedly write through anything) didn't leave a mark so I was guessing on the pinion nut. I did count the threads and tighten it to see how snug it was before I took it off. Test drive last night and oil still coming through the pinion seal. This is getting annoying. So now for the 75th time today I get to lay on a piece of plywood on the gravel and drop the rear half of the drive shaft and see if I can tighten it. This has gotten to the point of beyond pissing me off.... Anyone have experience with pinion seals on these? Its a 7.5" rear end. I replaced the pinion seal and nothing else other than the diff fluid but still have oil leaking through the seal and a growl sound whenever I let off the gas at higher speeds...
Get a sharpie professional, they write on oily power steering caps and wet Burger King cups and they're a $1 and some change at Lowe's, lowes has em the cheapest...
33659
rusty ol ranger
2.9L Mafia-Don
1,141
Michigan
2.9L
Anyone who could shoehorn an 8.0L V10 into an RBV would be an absolute god.
Id like to see one in a BII.
racsan
Well-known member
326
central ohio
1994 (mostly)
2.3/140-4
built, not bought
pulled the escape out of the garage and in to the front yard.
Ive had pinion seal leakage problems too, even after being marked and tigned back down. I think mine is just from wear, after all that axle I put in had nearly 200K on it. At least the axle seals arent leaking. I just top off the diff at every oil change, it really doesnt get that low, looks like more is lost than what is. “on the go” rustproofing. lol
Uncle Gump
Well-known member
1,115
Plano IL
Lead, Follow or get out of my way
91Stranger...
Pinion bearing preload is measured using an inch pound torque wrench. It will measure the rotational force of the ring and pinion.
The actual pinion nut will be in foot pounds of torque... which will far exceed snug. We are talking near or over 200 lb-ft in most cases. To achieve that torque it is common to use a tool to hold the yoke while torqueing the pinion nut.
Look up your spec and try again with a new seal.
Saddle Tramp
Active member
97
Florida
Can't believe I missed this.
Happy birthday PetrolemJunkie412's truck!
You too, dude. 👍🎉🙂
bobbywalter
TRS Technical Staff
548
woodhaven mi
FORD mostly
BIGGER
sawzall?
mmmmmmmmmmmm soup.
4.0blue98
Active member
173
Frederick, Maryland
4.0 OHV
Round
"eh screw it, its fine"
Cool. What kind of wine do you serve with that?
When you're done with it put it in a jug and drop it in Dirtmans yard...
BTW Happy Birthday, how old are you in truck years?
bobbywalter
TRS Technical Staff
548
woodhaven mi
FORD mostly
BIGGER
sawzall?
drop one off. i will get it in there.
