WHAT DID YOU DO TO YOUR RANGER TODAY?
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
Jim2
Honolulu HI
2.9 L
Uncle Gump
Forum Moderator
1,789
Plano IL
Lead, Follow or get out of my way
That is not only a cool song but one we all should live by just a little more. I'm tired of the dog eat dog mentality. Now pass the little Debbie's and a Mountain Dew this way.
Thanks for sharing Oldman...
91stranger
Well-known member
399
ohio
FORD
After I got my brake lines fixed I went for a test drive. Low and behold I had oil all over coming from the pinion seal again. Could it just not be tight enough? For those who don't remember, I thought I had a black line marked where the pinion nut was in respect to the pinion/flange but when I got it off, the part fell off and when I picked it up I couldn't see where my mark was. So I have no idea how the flange or pinion nut where other than I did try to tighten the pinion nut to see how "snug" it was and how many threads were showing before I took it off. Test drive was good. Got it up to 70 with no shaking or odd noises so I think everything is good however I may have overfilled the diff. Fill plug was rounded out so I had to drill a fill hole in the diff cover which was way higher than the fill plug so I just went but how much fluid I put in. So I need to double check the pinion nut.... again.... Oh and I would love to see a 2.9 run without oil in the pan or 2 less spark plugs... Does it use the coolant/oil mixture in the radiator to lube instead of the oil in the pan? That's how I understand 2.9's is they have all the oil in the world... in the radiator.
Ranger850
Well-known member
942
Tallahassee Florida
Stock 2"
Stock
They are Torque Thrust . They were a bit expensive (628.00) , but I had them on my '13 Mustang and really liked them . :icon_hornsup:
They look like "Cragar" Mag Wheels, real popular in the 70's. We have a '69 Mercury Comet with a set of those on it.
{poor Comet is rusting away in the woods of Arkansas as I type this, :cry:}
4.0blue98
Well-known member
292
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Fueled it up today. It runs much better when I do that every once in a while.
Uncle Gump
Forum Moderator
1,789
Plano IL
seems like another victory to me...:beer:
4.0blue98
Well-known member
292
Frederick, Maryland
4.0 OHV
Round
PacificGreen1998
Active member
181
Eustis Florida
3.0l Vulcan v6 with low miles...
stock since 1998
That one guy with ADHD and doesn't stop talking about cars.
Cleaned out bed of my truck a little bit but was too dark to take a pic this morning.....that and I don't think the egg nog had warn off quite yet....now I need to clean out my cab and the bed just a little more...
91stranger
Well-known member
399
ohio
FORD
Still having issues with the rear end. I think the pinion nut is loose. I "thought" I had marked the pinion nut and flange before I took it off but the damn marker (Milwaukee Inkzall which supposedly write through anything) didn't leave a mark so I was guessing on the pinion nut. I did count the threads and tighten it to see how snug it was before I took it off. Test drive last night and oil still coming through the pinion seal. This is getting annoying. So now for the 75th time today I get to lay on a piece of plywood on the gravel and drop the rear half of the drive shaft and see if I can tighten it. This has gotten to the point of beyond pissing me off.... Anyone have experience with pinion seals on these? Its a 7.5" rear end. I replaced the pinion seal and nothing else other than the diff fluid but still have oil leaking through the seal and a growl sound whenever I let off the gas at higher speeds...
Cees Klumper
37
Marina del Rey, CA
Bronco II XLT
I checked for codes on my new-to-me 90 Bronco II with the 2.9 V6. To my positive surprise, it came out all clean! Not a single code. It does run very well, except for a rough cold start first 2 or so minutes after it has sat for a few days. Going to replace injector seals, intake manifold gaskets and such and hope that will clear that up.
PetroleumJunkie412
2.9 Mafia
2,926
Pittsburgh, PA
If you take care of a 2.9, it takes care of you. 👍🏿
snoranger
Forum Moderator
ASE Certified Tech
2,177
Jackson, NJ
'79,'94,'02,'17
All Fords
Dirtman
Clam chowdah!
EMT / Paramedic
4,553
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
Your just gonna convert that into poo! Happy birthday!
