snoranger
Professional money waster
ASE Certified Tech
13,599
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Not my Ranger, but…
I went over and checked out my uncle’s 2010 Ranger. He offered it to me for a very reasonable price. He’s got a new Ranger on order.
JoshT
1,646
Macon/Fort Valley, GA
I drove the 99. Aside from a trip around the block a few days ago, this was the first time it was driven in over 1.5 years. I parked it back then with a fresh oil change and a nearly full tank of gas. Oil still looks good and same gas. Drove the ~30 miles to my parents house flawlessly. Aside from that I've been slowly cleaning the interior over the last week. Today was spent trying to fix a 4-wheeler so I can use it to get a nother deer in the freezer after Thanksgiving.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
The newest addition to the family...
@85_Ranger4x4 what's the best Bronco forum?
rubydist
851
Denver
Ford Ranger FX4
bronco6g.com is by far the best.
scotts90ranger
4,311
Dayton Oregon
2.3 Turbo
Well, I sure did something to the '97 today... likely "technically" totaled but I'll fix it... Rear ended a Tacoma earlier today, did a number to the Ranger but the Tacoma probably just needs a rear bumper or some massaging on the rear frame horns and probably a new tailgate (minor dents but cheaper to get a new one likely...). The Ranger on the other hand will need a radiator, grill, front bumper (I'll wait till I find one), some massaging on the hood hinges, some tweaking on the core support and the passenger fender, some headlights or turn signals at least and apparently the timing belt skipped a tooth or something since it won't start and sounds funny cranking. I'm also guessing the drivers side motor mount went since the engine went far enough forward for the oil filter to hit the motor mount bracket... It's currently sitting on a trailer at my brothers house, I'll get a radiator and timing belt and fix it over there then drive it home hopefully on Friday. Towed it there with a 2500 Chevy van with a 4.8L, that van is a trooper... The important thing about it is the guy with his wife and kid in the Tacoma were all fine and me and the wife are both fine, we're a little sore from seatbelts and me from pushing on the steering wheel... we had to be going about 10mph when it happened I guess. I found out they moved the inertia switch to the other side of the passenger floorboard, so there's that...
I have a couple pics, not in the mood yet...
Blmpkn
Toilet enthusiast
6,358
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
2500 van with a 4.8? That's a new one 🤔
Sorry to hear, at least everyone's alright!
scotts90ranger
4,311
Dayton Oregon
2.3 Turbo
The chevy vans only came with a 4.8L or 6.0L, no 5.3L... so yes, a 2500 van with a full floater (I think, pretty sure I looked...) 14 bolt rear axle, a 4L80 transmission and a 4.8L, was a plumbing van, got it a few years ago for $2500 down the street from my work... it's a bulletproof combo, little underpowered but not bad...
On the positive side, only a 3 day work week so 3 days of driving the '98 V8 Explorer at 16mpg vs 23mpg won't hurt too much, only about $200 in parts to get I think so far... we'll see on Friday...
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
I drive a 2500 with 4.8 for a work van. Solid good working van
racsan
4,420
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
big temperature drop, corrected the air pressure in tires on both the escape & the ranger. The escape was off the most, but those tires hold a larger volume of air so id expect that. Transferred 400# of softner salt back into the bed of the ranger in case we get any substantial snowfall.
Ranger850
Doesn't get Sarcasm . . .
4,678
Tallahassee Florida
Stock 2"
Stock
lil_Blue_Ford
6,065
Butler, PA, USSA
4.9L
Hopefully I’m doing some junkyard shopping today. Figure I have today and tomorrow to do it then I have to get back home. Also hopefully I’ll finally manage to get a driveshaft for the F-150.
JoshT
1,646
Polished out the headlights. Found a product that I can actually recommend.
3M 39008 Headlight Lens Restoration System
Comes with 2 grits of sanding discs, a "refining disc", a buffing pad, a holder for the discs to use in drill, and a little rubbing compound. Mounted it up in my 1/2" chuck corded drill and spent an hour or less to knock out both headlights. Don't need a 1/2" chuck drill, but it's the only one I have with an auxiliary handle which was nice for handling and control. Once buffed I applied a little spray on wax to hopefully keep them looking fresh a little longer.
No before and after pics. I didn't put a lot of effort into getting it superdetailed and cleaned, just getting it to where light is on the road. The area that I used the kit on is atleast as clear as when they were new. Another day I might pull the headlights and marker assemblies and do a thorough cleaning.
For $35 at the local autoparts store I think it was a prety good deal, and I don't mind repeating again in a year or two at that price. If one were going to do it a lot they could probably piece together their own kit online for less per light cleaned.
Liked it enough that I went and bought another kit to drop off at the parents house for dad to do it on mom's car sometime soon.
17,755
SW Iowa
Only when I need to look something up.
I can't stand the "community"... Or lack thereof over there. Everybody is so mind boggling negative it is maddening.
BII corral is OK but there are only like three of us over there.
lil_Blue_Ford
6,065
Butler, PA, USSA
4.9L
Nothing to the Ranger, but I finally got a rear driveshaft for the F-150!!! :yahoo::yahoo:
Tomorrow may land a few more junkyard goodies, then it’s time to load up and head home
sgtsandman
Aircraft Fuel Tank Diver
12,535
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
That kit may be different than the others I’ve used and what others have used. Meaning the head light lens might stay that way. The ones I’ve used were maybe good for a year unless you clear coated the lenses. Without a protective coating, they just haze over again.
