Jazzer
457
Indianapolis
I got my upstream o2 sensor out and replaced it. Wire was too short. Turned out AZ sold me the wrong downstream sensor earlier (long wire) and Rockauto sent me the wrong upstream sensor (short wire) so I just switched them.
I noticed too much negative camber on my front passenger wheel. I'd recently replaced the upper control arm, so I knew I'd done something wrong. Long story short, on my '07 (2wd coil) forward control arm bracket, where the mounting bolt comes out to receive its nut, Ford put a square washer with two adjacent clipped corners and an off center hole. I had it with only one clipped corner on top, but the drivers side had both clipped corners on top. I rotated the washer so that both clipped corners were on top, and that pushed the forward arm outboard, and that restored the camber. I set toe in with the laser and it drives fine.
-Jazzer
ericbphoto
Overlander in development
16,594
Wellford, SC
6"
Gave mine a quick wash yesterday. Much easier to pressure wash the underside while it's still on the trailer. Going to lube it this afternoon and park it in the yard on the trailer. Planning to go camping and wheeling at Gulches with a group from FMC (Fully Mission Capable) in another week.
RustyShackleford94
Just some guy
355
IN
Nothin yet but the ball joints got here. Been parked since it tried to steer itself into a river Tuesday.
fastpakr
2,832
Roanoke, VA
Still chasing down the rough idle on mine. Tried swapping coil packs today with no effect. Need to figure out a good way to do a balance test.
Saddle Tramp
748
Florida
Not mine but I sent my brother in law a Rock Auto link for a new rear bumper for his 200 sport flair side.
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
Fixed the handle for the red truck last night. Ended up being that the clip that holds the rod to the handle came undone so only one side was opening. Was able to adjust the slop out of the other one while I had the tailgate apart.
Jazzer
457
Indianapolis
I dropped the donut spare and aired it up. Then I Fluid Filmed everything I can't get to while it's in, and cranked it back up.
-Jazzer
RustyShackleford94
Just some guy
355
IN
To much for nothing. Changed ball joints, all the tie rods, wheel bearings, rotors, pads, and the axle joints. Threw it on bros alignment rack, set toe to zero, camber and caster are equal side to side and in the green. Damn thing still wants to steer itself. Either the frame or the rear end is tweaked though. Probably going to throw it on his frame machine tomorrow and yank some shit back into place and see what happens.
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
was going to take the seats out & start on the interior, pulled out the drivers side floor mat and found I have some patching to do before I do much else. I had patched a small spot close by a couple years ago. Picked up some foam tape, its about time to put the cap back on.
ericbphoto
16,594
Wellford, SC
6"
Jazzer
457
Indianapolis
^ Beat me to it.
-Jazzer
RustyShackleford94
Just some guy
355
IN
You need some Toe in. I usually set the front of the tires at least 1/8" narrower than the rear.
Im not an alignment guy lol. Still shouldnt be trying to steer itself lol.
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
RIP the red Ranger. Accident yesterday wiped out the front end. Bent both frame horns. Car that got me didn’t take it as well though. Not sure yet how it’s all going to shake out. Concussion has me :black_eye::black_eye:
