bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Well. .
Smooth as silk till the plugs foul....
:blush:
17,827
SW Iowa
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Well....you might just be on to something there...
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Jazzer
457
Indianapolis
Finally got the new power steering reservoir to replace the leaking one and installed it. Tried to replace the upstream 02 sensor but no go. It’s soaking in PB Blaster.
-Jazzer
ThatOneGuy
575
South sound
Ranger Explorer
Explorer is 4.0 ranger is 2.3 soon to be 4.0
Let the universe take you where it will !!!
Picked up my rocker arms yesterday, and gonna get my push rods today. Both Melling brand
ekrampitzjr
1,067
Virginia
Yesterday I replaced the front brake discs/hubs including new bearings. Every trace of old grease was cleaned off spindles and the other parts you would keep. The new-car dealer (not Ford) had mixed new red grease with the old gray grease when dressing the old brake discs, and I determined that the two types were incompatible and breaking each other down. It was a good thing I did the work now.
The driver's side spindle had a small area of surface corrosion that polished right off with fine-grit sandpaper. Possibly a drop of water got in the works when that dealer was messing with the brakes.
Originally I wanted to reuse the old discs/hubs, but the bearing cups (outer races) would not budge despite whaling on them with flat punches and a 3–pound maul. I managed to bend a punch. :eek: Instead of trying to find someone with a press, I gave up and got new discs/hubs to get the job done. One great thing about Rangers is parts availability. NAPA had them in 2 hours.
The new Timken bearings and other parts have been greased by hand with Red Line CV-2, a full-synthetic orangeish-red grease with moly. Each bearing was rotated by hand before installation to circulate the grease.
As I was putting everything back together on each side, I followed Ford instructions for preloading the bearings to 17–25 ft-lb, then backing off the nut 1/2 turn for retorque. But my smaller 1/4" drive torque wrench would not click when set at 20 inch-pounds, the bottom of its range. In a pinch I ended up tightening the nuts to be just a little snug, which allowed free wheel rotation with no play. Now when you rotate either front wheel with it off the ground, it rolls and rolls and rolls smoothly.
After a test drive at low speeds to make sure the grease was circulated, a trip at highway speeds went very smoothly, and the brakes stop better than ever. Seems like a success.
ekrampitzjr
1,067
Virginia
Hey, I hope no one finds these details too boring. I hope it's helping someone else.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
The corrosion on the spindle....I consider..free bearing mount....keep that race parked
scotts90ranger
4,367
Dayton Oregon
2.3 Turbo
1/3 of the way to work this morning my battery light came on, looked down and the voltage was low... rev up to 3000rpm and the battery light went out, go up to 4000 and the voltage came up... alternator went out... cruised the rest of the way to work at 3000rpm (2.3L, it don't care, that's where it lives...) and ordered one which they delivered at about 8:30, just got it in on my lunch break so it's good to go!
Convenient that it's 95A but it's somewhat spendy although easy to change... 3 bolts, two connectors and a nut for the charge wire...
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Cleaned the 2011 inside and out. Waiting on pay day to change the axle fluids (front due anyway), transfer case fluid (due), engine oil & filter (due), and may be engine air filter due to the dust from the off road fun. It was just replaced in June, so it may be perfectly fine.
ThatOneGuy
575
South sound
Ranger Explorer
Picked up head bolts and push rods for the 4.0
97RangerXLT
3,937
Fishers, IN
2"
31"
Like @sgtsandman , cleaned mine inside and out. And now it is storming out lol
AJ
sgtsandman
12,646
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
My idea of cleaning.....park on grass....suppose to rain bad tonight.
