Poses in rivers
20,728
SW Iowa
I know what I was doing to my Ranger 14 years ago today...
WutUp Clegg
60
USA
I understand that it's in the shop now and hopefully they'll get you straight.
What codes was it actually giving you? Preferably the code numbers rather than the nomenclature since the nomenclature can vary with source.
Codes may mention parts, not saying that the part is bad. Usually it's just saying that the sensor indicates a certain condition that the system can't correct, but it is something other than the sensor causing the condition.
I don't remember the codes. I do remember it was reading as running rich, MAF issues, O2 sensor issues, etc... I checked and replaced all of those things, but it still reading rich without giving me an exact problem. The mechanic found the intake was leaking at the left-side head. Hopefully that will fix the issue. I'm tired of throwing parts at it. On the other hand, many of those parts were bad, including the Y-pipe with the cats on it.
Rick W
Lil Big Rig
Truck of Month
TRS 25th Anniversary
5,794
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
Rick W
Lil Big Rig
Truck of Month
5,794
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
UPDATE: remanufactured 130 amp alternator delivered to the house, $80. Pull a Part price was about $40 with tax and core charge. Add gas, no brainer….
I looked all over the place for a serpentine belt, and couldn’t even find one locally for a 4.0 with air conditioning. Then I went to rock auto, and they had four or five of them under $25. It’ll be here in about a week
Update update: when I pulled the alternator to swap the brushes, the Belt tensioner didn’t seem to want to come up all the way. It did, but if I touched the wrench a little bit, it would come up just a little bit more. I don’t think the belt was slipping, but I ordered a new tensioner anyway.
Poses in rivers
20,728
SW Iowa
CamTheHedgehog
ASE Certified Tech
775
From Charlotte, NC; Living in Lansing, IA
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
I listened to the engine.
A few things to note. One, my alternator bearings seem to be going out, so I’ll need to get that sorted soon.
Two, I about freaked out when I noticed a faint ticking noise, not the dreaded chain rattle but something else. After listening closer and putting my finger (carefully) on things to feel for vibrations, I can say with reasonable confidence it’s just injector tick, as it’s softer and more solenoid-like than lifter tick. And, yaknow, it’s coming from the injector area.
Also my valve cover gasket on the passenger side is leaking already… smh. It’s been less than 10k.
Bill
1,062
Sacramento, CA
So, sunday I finished rebuilding the suspension on the driver's side. While driving to work I noticed a popping sound when going over bumps. When I got home I inspected my work. Everything was torqued properly. I then started looking for movement and I found it. The upper control arm ball joint was loose in the top of the steering knuckle After trying to figure out why I popped out the caliper to measure the ball joint stud in the old control arm and the new one. They were both the same. I measured the new bolt that came with the control arm. It had a slight taper going toward the threads. A difference of about 1.5 mm. The part of the bolt that pins up against the ball joint stud was the same as the old bolt. I decided to reuse the old bolt and the problem appears to be resolved. Then I attempted to re-center the steering wheel by adjusting the toe. I made some improvement, but it was getting dark so I quit.
Rick W
Lil Big Rig
Truck of Month
5,794
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
You probably know this, but just in case you don’t, you can cut a piece of one by two or use a dowel or something like that, and carefully touch it down on different parts of the engine with the other end against your ear. It’s like a stethoscope, it magnifies whatever noise, hunting around you can isolate it
My 2 cents, hope it helps
Poses in rivers
20,728
SW Iowa
A long screwdriver or prybar works too.
scotts90ranger
5,559
Dayton Oregon
2.3 Turbo
Saturday I took the '00 Explorer up in the woods hunting, hadn't driven it much in the last year since I welded the rear diff last hunting season :). It's kinda annoying having a welded diff in the city as it squeals tires all the time and really wants to go straight, but get to a gravel road and it's a frickin blast! Stab the gas, drop a gear and you get all the powerslides...
They say welding a clutch type limited slip isn't recommended, heck I'm not recommending it, I was out of spare parts and time so it's the route I took, honestly kinda amazed it's taking this abuse... I pre heated then welded until it looked like there was absolutely no gain in adding more metal in there, then added a little more then put a 5 gallon metal jug over the carrier and put a few towels over it and let it cool naturally, then reassembled the next day... If you're gonna be dumb at least be smart about it...
lil_Blue_Ford
Cut & Weld
7,621
Butler, PA, USSA
5.0l
4”
A long extension for a ratchet works well too
Somewhere I do have a mechanics stethoscope but I don’t remember the last time I used that over whatever was handy to transmit sound
lil_Blue_Ford
Cut & Weld
7,621
Butler, PA, USSA
5.0l
4”
Replaced a tailgate cable on my green Ranger yesterday with one that is less broken. Had to fight the stupid bolt. Ordered new cables.
Worked on welding on dad’s Ranger. Got the tab by the body mount done. Tried to get the one other tab on and it didn’t fit quite right so I was working on fit and I managed to put a twist in it and there’s no room to work because of the fender liner. Got frustrated and left it at that for the day. Took care of a few other things.
Gonna have to take the fender liner free to get room but I’m thinking today I’ll probably see about changing the oil in the green Ranger, maybe work on the crossmember for dad’s Ranger, maybe work on the 88.
Rick W
Lil Big Rig
Truck of Month
5,794
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Alternator and belt came in today for the Road Ranger. They weren’t supposed to be here till the weekend or Monday. I still have to wait on the belt tensioner.
Some progress though. Fuel pump is supposed to be here Tuesday.
4.0blue98
I don't feel tardy...
732
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Turned 220k. Still my daily driver. Needs brake work and I think I blew out my catalytic converter. Don't tell Al Gore...
CamTheHedgehog
ASE Certified Tech
775
Ranger Edge
4.0 SOHC
That reminds me…. I think mine is going bad.
I’m getting a little bit of rattle/grinding noise, similar to the dreaded chain rattle but from the top front of the engine.
My giveaway that it’s something in the accessory drive is that it’s quite faint from the wheel wells, but very prominent from the front through the grille and radiator. If it was the chain rattle, I feel like there’s no way the sound would carry better through the accessory drive and radiator than through the wheel wells. Also from my experience with the rattle it comes very clear through the wheel well if it is the chains.
why am I writing this? To calm my fears that it is somehow the chains AGAIN and not the accessory drive. If it is I will have a literal stroke.
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
