Wallows in rivers
20,890
SW Iowa
scotts90ranger
5,610
Dayton Oregon
2.3 Turbo
The friend that I'd sold the '92 to brought it back today... his son lost interest, at 18 I understand... I'll get it going, probably pass it off to my brother once it is up and reliable...
To pull it off my buddies trailer I used the Explorer since it's an auto and easier...
JoshT
3,114
Macon/Fort Valley, GA
Nothing today, just felt drained and slept most of the day.
Was released from work early yesterday. After the hurrican blew through thrusday night and friday morning, most of the mechanics were out and without them us office workers have nothing to do. Swung by the salvage yard and did some window shopping. Bunch of odds and ends needed for various projects, but I didn't have the right tools for most of it. I already had an 01-03 header panel for facelift on the 99. Was able to snag a lot of the small hardware sparts. Found an Edge with a good insert, but the shell broke on removal. If it is still available I can get a cheap/free grill shell from a co-worker, but it was missing the insert and some of the clips. Set of headlights, some wiring, and some paint and I'll be set for the facelift.
Will be going back soon. Found a first/second gen rear speaker box set w/mounts set I want to grab for the 85, but I didn;t have wirecutters or a long enough screwdriver. Interested in possibly grabbing a set of seats to swap into the 99. Spotted some mustang seats that looked decent, also some from a focus. May grab the hood for a spare when I go back. I've already got the Edge hood installed, but no one is making replacements and dad's ranger also has that hood.
Recieved the smoke tester for leak checking the Ranger's intake, will hopefully feel like tackling that tomorrow.
rubydist
984
Denver
Ford Ranger FX4
The salvage yard must have been an adventure after all that rain...
JoshT
3,114
Surprisingly not. There was some standing water but almost the whole place is covered in gravel, so it drains off pretty well and not a muddy mess. Biggest issue is that the last time they spread gravel the stuff they got was a bit too large, makes it a little rough walking and pulling a cart.
scotts90ranger
5,610
Dayton Oregon
2.3 Turbo
Went looking at my brothers stash of roofing metal to see if it was the same as mine (it is) since I need two more pieces instead of overlapping 3 4' pieces to make up 12'... we found a pile of tires that was apparently closer to the apple tree than it was in the spring :), that broke the passenger front mudflap on the '97 Ranger, so I took it off and fixed it again (was broken when I got it, it broke in a different place amazingly, my craptastic weld held up somehow)
Rick W
Lil Big Rig
Truck of Month
TRS 25th Anniversary
5,836
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
I’m going through one of those times we all experience with older vehicles where there’s something wrong with everything at the same time, and I’m trying to work through one by one in order of priority.
I got the brakes done on the Road Ranger, but nobody handy to help me bleed them right now. 😤
I did a quick look under the hood of the F250 to see if I could spot the vacuum leak for the AC. Nothing obvious. I don’t like to work on stuff out front, so I decided to move it around the back.
I’ve been driving the Missing Linc, and I’m just keeping up with the oil level in the rear end, and listen to that clickety-clack to make sure it doesn’t bust something. I don’t want to take it apart till I’m sure something else is running and stopping.
So I got in to move it out of the way for the F250. Turn the key, nothing. 😤
Almost brand new battery, dead as a door nail. So I got the smart battery charger, and when I was putting on the positive clamp, I heard a crackle and my strobe lights came on. I took a closer look, and the clamp had cracked. It’s one of those pressed sheet metal clamps, not the lead clamp. No big deal, I’ve got a box of cables and another box of clamps.
Once I started, I didn’t want it cobbled up, so I took a brandy new cable I had. I think I got it by accident and then they credited me, and I just made a new cable. I cut it the length I wanted. I cleaned up a pretty solid heavy duty clamp I had. I spread the wire out a little bit, and put soldering paste all over it. I crimped it over the wire. Then I dropped my mini butane torch and broke it…. 😤😤😤
I ordered a new little torch from eBay. I’ll solder it when it gets here. It never ends… 😤
so I ended the day where I thought I started…
scotts90ranger
5,610
Dayton Oregon
2.3 Turbo
Last night I ordered some cheap shocks for the '97, was like $90 for all 4... ought to ride better than only having a functional drivers front shock...
alwaysFlOoReD
5,804
Airdrie, Alberta, Canada
’97, '06
Pontiac, Dodge
2.2,5.7
I made a vacuum bleeder using engine vacuum. A mason jar with a hose long enough to run from engine to the farthest tire, sized to fit the bleeder valve, and a short hose to reach from mason jar to bleeder valve. Drill 2 holes in jar lid just big enough to have a tight slip fit for the 2 hoses. Attach long hose to a vacuum source on engine and fire it up. The bleeder should be cracked open. You will probably see some bubbles but just keep vacuum on until fluid runs clear. Don't run the master dry!
97RangerXLT
4,641
Anderson, IN
2"
31"
Could you tell me what length brake line and part #s for this project? I'm gonna be doing same this wknd and not sure on what length to order
I am sorry that I missed this until now... I got all of my lines and most of my fittings from Rock Auto. had to get one of the Master Cylinder fittings from Autozone. basically you want nickel copper alloy lines. here is the list from Rock auto for all of my parts except the booster. runs just shy of 300 bucks for all of this:
AGS​
CNC325KBrake Line
$ 33.79​
$ 0.00​
1​
$ 33.79​
AGS​
CNE3 (CNE360)Brake Line
Length: 60"
$ 9.27​
$ 0.00​
1​
$ 9.27​
AGS​
CNE3 (CNE340)Brake Line
Length: 40"
$ 7.60​
$ 0.00​
1​
$ 7.60​
DORMAN​
80189Power Brake Booster Check Valve
Wholesaler Closeout -- 30 Day Warranty
$ 2.35​
$ 0.00​
1​
$ 2.35​
DORMAN​
13911Brake Bleeder Kit
$ 3.89​
$ 0.00​
1​
$ 3.89​
1997 FORD RANGER 4.0L V6
CARLSON​
H94722 (H9472-2)Banjo Bolt / Washer
$ 2.15​
$ 0.00​
2​
$ 4.30​
DORMAN​
HW1457Brake Hose Clip
$ 0.53​
$ 0.00​
4​
$ 2.12​
DYNAMIC FRICTION​
35054342 (350-54342)Brake Hose
$ 16.69​
$ 0.00​
1​
$ 16.69​
POWER STOP​
L4606Caliper
$ 34.79​
$ 12.00​
1​
$ 46.79​
POWER STOP​
L4607Caliper
$ 34.79​
$ 12.00​
1​
$ 46.79​
RAYBESTOS​
BH380389Brake Hose
$ 15.89​
$ 0.00​
1​
$ 15.89​
RAYBESTOS​
MC390268Master Cylinder
$ 59.79​
$ 0.00​
1​
$ 59.79​
RAYBESTOS​
BH38813Brake Hose
$ 13.90​
$ 0.00​
1​
$ 13.90​
the top three are the brake lines. one 40 inch piece and one 60 inch peice are for the master cylinder, and they have preformed bubble flairs so you don't have to get a special tool to form them, (ended up getting that tool anyways because hey, new tool...) just cut one of the ends off and replace the tube nut on the 60 inch one to the bigger size that I had to get at Autozone... both of those lines are almost perfect length to do the master cylinder to the driver front wheel (40 inch) and master cylinder to the RABS pump (60 inch) then get the the 25 foot coil with the assorted fittings (see Uncle Gump's pic) and that should have most of what you need fitting wise to do the rest of the lines. I did not do the line from the RABS to the back axle as it looked ok and you need to remove the bed and gas tank (which was near full) to do that one. but I have the NiCop line for when I do get around to it. the NiCop line is really easy to bend, so you don't need a tube bender. I was able to do all of my bending by hand. tip on the lines... it may be easier to just leave the old lines in place and route new lines in by hand. (thank you @bobbywalter for that suggestion..) I did remove the old ones on mine, and it was a royal pain in the ass. the front one that connects the two front wheels I did not pre bend, I just fed a straight section of line and bent it as necessary to follow the frame and crossmember.
the line thickness is 3/16" if you are unsure of what type of line.
Hope this helps.
AJ
lil_Blue_Ford
Cut & Weld
7,719
Butler, PA, USSA
5.0l
4”
AGS​
CNC325KBrake Line
$ 33.79​
$ 0.00​
1​
$ 33.79​
AGS​
Length: 60"
$ 9.27​
$ 0.00​
1​
$ 9.27​
AGS​
Length: 40"
$ 7.60​
$ 0.00​
1​
$ 7.60​
DORMAN​
$ 2.35​
$ 0.00​
1​
$ 2.35​
DORMAN​
$ 3.89​
$ 0.00​
1​
$ 3.89​
CARLSON​
$ 2.15​
$ 0.00​
2​
$ 4.30​
DORMAN​
$ 0.53​
$ 0.00​
4​
$ 2.12​
DYNAMIC FRICTION​
$ 16.69​
$ 0.00​
1​
$ 16.69​
POWER STOP​
L4606Caliper
$ 34.79​
$ 12.00​
1​
$ 46.79​
POWER STOP​
L4607Caliper
$ 34.79​
$ 12.00​
1​
$ 46.79​
RAYBESTOS​
BH380389Brake Hose
$ 15.89​
$ 0.00​
1​
$ 15.89​
RAYBESTOS​
$ 59.79​
$ 0.00​
1​
$ 59.79​
RAYBESTOS​
BH38813Brake Hose
$ 13.90​
$ 0.00​
1​
$ 13.90​
the line thickness is 3/8" if you are unsure of what type of line.
Hope this helps.
AJ
So, it’s a bit of a miserable task but it is possible to fish a line past the gas tank without removing anything. I’ve done it a few times. Beats trying to drop a gas tank but it’s still not exactly fun. A lot easier to do with the bed off, however. In my opinion, a bed is easier to pull than a gas tank. So if that line isn’t leaking but I have an excuse to take the bed off like a fuel pump, or rust repair or suspension repair or something, well, then it’s getting a new rear line whether it needs it or not because it’s pretty simple right then.
And I believe you mean 3/16“ line, I’ve never seen bigger on the 83-11 Rangers except ones that have been modified.
97RangerXLT
4,641
Anderson, IN
2"
31"
yes you are correct, 3/16th.
and yeah that is how I feel about it right now, let it slide and when I need to yank the bed for something, that is when I will do it. also loosening the gas tank and let it rest on the skid plate will give me more room to mess with the lines as well. did that when I did the springhangers in 2012.
AJ
Maritime Drag Racing
1,056
Sydney, Nova Scotia, Canada
355 Chevrolet
2" drop rear shackles
27 X 5 X 15 Hoosier front - 9X30 Goodyear rear(slicks)
Race it - Break it - Fix it - Repeat
Our track photographer sent me another pic - this was about a foot off the starting line.
Rick W
Lil Big Rig
Truck of Month
5,836
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
I didn’t think to try that, but that makes an awful lot of sense. I have one of the little harbor freight hand vacuum bleeders, which has worked for me on other vehicles, but the best I could do is get spongy brakes. On that particular rig with that bigger trailer, it’s not something I want to experiment with.
I have a volunteer coming tomorrow after work.
scotts90ranger
5,610
Dayton Oregon
2.3 Turbo
No pics but I did a hurting on the clutch on the '97 tonight... the boss sold the old broken shop truck ('14 Silverado 1500 crew cab with 6.2L di engine but had the lifters go out and took the cam out, thought about buying it but don't need another project) and the buyers came to pick it up with a tilt trailer but didn't have a come along (engine is apart, non runner) so I offered the Ranger, wasn't in the mood to unlock things just to get a forklift... now I know how close my clutch is to going out, it's for sure a winter project at this point :), I'll be able to limp it along for a while.
Rick W
October Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
