MotorBoater
Great Great Grandson of Harry Herbert Bennett
5
Tacoma, WA
Yesterday I,
  • disassembled and added heat shroud on new up and down stream O2 sensors,
  • wrapped the exhaust (waaaay easier with manifold off of the vehicled..)
  • didn't push it off a cliff
  • cam sensor,
  • and reinstalled the entire wire harness I made new again. ......Still only starts with remote trigger and not key start dammit :/
Today I'll be,
  • testing for leaks with my new smoke machine from Amazon!
  • Diagnose overheating issue (im thinking thermostat or the temp sensor next to it)...
  • compression test
  • vacuum lines
  • calming down with a cigarette
tw205
Bronco II Rancher.
709
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
I bought this parts truck to be disassembled with the goodies to be distributed between two of my BIIs. 95 XL 4.0 4x4 5 speed reg cab short bed She got vandalized a couple years ago and has been waiting for me to find her.
Broken glass, torn off cat, jacked up ignition switch and rusted out shackle are her larger faults. I know she’s a parts truck but it’s in my nature to fix things. I can’t help it! DONT JUDGE ME!!! So while bench building ( drinking beer in the barn ), I found a wrench in my hand that just happened to fit the spring eye bolt. So I removed the rusted out remains of the shackle and cleaned it all up well just because. Then I somehow found myself under the dash wiring an ignition and start switch to bypass the jacked ignition switch ( which is in the run position ). So now she starts and shuts off without having to jump the relay and shuts off without killing it with the clutch and the battery can stay connected. She fires right up and runs like a champ. I keep wanting to dislike her enough to stop but I can’t. So $400 for a new windshield? I’ve already got a rear window. No inspections here so I can straight pipe that lack of cat thing. She may have to be my new beater with a heater. And A/C. Did I mention she has almost no rust on the body, even underneath. But she’s covered in whiskey dents but then I won’t worry about scratching her. IDK. Maybe a therapist would be cheaper. I need a bigger barn.
Rick W
2,808
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
I bought this parts truck to be disassembled with the goodies to be distributed between two of my BIIs. 95 XL 4.0 4x4 5 speed reg cab short bed She got vandalized a couple years ago and has been waiting for me to find her. View attachment 102026View attachment 102027
You may want to shop around on the windshield. Our local string of pull a parts have glass shops. I put a brand new windshield in my 87 for $165. That was a couple years ago but I don’t think it’s changed much.
Hope it helps
And my vote would be to save it….
pjtoledo
2,556
Toledo Ohio
Fords
3.0 2.3
that bed sure looks tempting :nono:
I'm less than 2 hours from you. :bye: :nono::nono::nono::nono::nono::nono::nono::nono::nono:
tw205
Bronco II Rancher.
709
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
That bed had the most dents of all. But no rust holes. My daily BII is rusting pretty good but I keep patchin what I gotta. Just filled the drip rails with JB weld. Rains comin.
pjtoledo
2,556
Toledo Ohio
Fords
3.0 2.3
I already have fenders & tailgate, it's the floor and front panel I'm on a quest for.
speaking of rust, the splice where front & rear frames overlap at the front spring hanger is tough to repair.
it rusts on the inside. if you're going to save this Ranger give that section a good workout with a hammer to test for soft steel.
ben_2_go
246
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
Today I fixed a plugged windshield washer squirter on the passenger side. I decided that since I was going through all that trouble, I'd wash the road grime off my windshield. That lead to me washing and polishing all of my glass inside and out. At which time I tried to wipe my window wipers blades off, and they fell apart, so it got new wiper blades.
scotts90ranger
3,699
Dayton Oregon
2.3 Turbo
Made an appointment to get a new windshield on the '97 today for next Monday, Safelite sent me a $50 coupon so it's less bad, for whatever reason it's cheaper to get a new windshield with new wiper blades so I'll see if one of the explorers has worse blades than the Ranger before then, I know the '90 does but I think they're different mount style and don't have the parts, the two sploders are the same...
tw205
Bronco II Rancher.
709
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I have another parts truck with a good bed floor. I don’t know what years work for you but it an 85 short bed. Let me know.
pjtoledo
2,556
Toledo Ohio
Fords
3.0 2.3
I'll be piecing stuff together to make a custom bed, anything 6' long will work. (or longer)
the '85 has narrower frame rails than '95 right?
that won't matter, I'll make it fit. :icon_thumby:
plus I'm looking for another excuse to drive over to The Saucy Dog in Jonesville.
tw205
Bronco II Rancher.
709
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I’ll get some pictures tomorrow. It’s at my brothers and I gotta drop off a quad there anyway.
Manscout
77
Gillette, Wy
33x12.5x15
Just put the raised Ranger lettering on the Tailgate before it gets too cold out. I'm not sure if I like it yet. It could grow on me I suppose . Your thoughts?
Since you asked.....
I'd get rid of the dealer badge. It would help your lettering stand out more.
Here is mine with the flat vinyl letters.
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
420
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
Apparently it's too late now. I can't remove the letters, and the Ford Logo was affixed with Silicone. I don't want to create a monster, so I'm leaving it be. But thanks anyways.
sgtsandman
Aircraft Fuel Tank Diver
11,166
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The Ford logo has two pins that go into holes in the sheet metal too. At least my 1998 did. You’ll need to fill in those alignment holes and paint if you want to remove it.
