Oh manā¦
I went at the green Ranger project again, figured Iād tackle swapping rear axles today and came away very irritatedā¦ for something thatās been apart before, by my hands no less, it sure didnāt act like it. The donor rotted out Explorer came apart easier than this. I know I would have coated every bolt in grease. Iām absolutely baffled. The U-bolts (which I never touched) came apart easily. The sway bar links (which Iāve had apart), one was seized on the bottom and the top of that side I had to cut. The other side came apart easily. The shocks, the one shock ate all the way through the threads on the bottom, the other was perfect on the bottom, but took 5 minutes of pounding 1,400 ft/lbs of impact gun to it, no joke. Both tops were normal fight.
But the leaf spring boltsā¦ all four were dry as a popcorn fart. They should have been drooling grease. Of course, with the bed on, canāt really get an impact on them, but they should come apart nicely, right? Nope. The first one I tackled I ended up with the 3/4ā ratchet on it (the handle is like 3ā long) and snapped that MFār right in half. So I had to cut up on the other side of the bushing because what was left wouldnāt punch out. Of course the 4-1/2ā grinder wouldnāt get it and I didnāt want to pull a cord so it got the sawzall. Second bolt was a fight, had to unscrew it all the way. Third was just awkward because somehow, it got put in from the frame out on the hanger, which I never do because you canāt get it out again with a hitch on the truck. Last bolt, was a fight and I thought I might break it, but then it unscrewed out slowly.
That whole mess is out now though, so I gotta finish prep on the Explorer axle and then once I build the new packs, it can go in. So much for having it ready for the springs today. Tried getting the yoke changed on the driveshaft today too and thatās also halfway done. Knocked the yoke off the driveshaft and the old joint out. Joint felt ok, but should probably get cleaned out and repacked with grease, so I just figured Iāll throw a new joint in for now. Tried to knock the junk U-joint out of the yoke I need to use and couldnāt get the clips out, they both broke and in such a way there was nothing really to grab. Got mad and cut the cross and punched out the ends, but still have to figure out getting the last of the clips out, theyāre wedged pretty good.
