pjtoledo
2,953
Toledo Ohio
Fords
3.0 2.3
Today I get to replace the passenger side window regulator/motor with a working spare.
I can't wait to drill out the rivets that are holding it in....:rolleyes:
the rivets are easy. punch the center pins out. start drilling. when the base starts spinning tilt the drill an inch or two. it will chew right thru the base as it spins.
rumblecloud
1,110
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Got through all five with no swearing. It wasn't as bad as I remember. Thanks
alwaysFlOoReD
5,080
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Uncle Gump
Token Old Guy
13,423
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It bends like butter and lasts forever. I nicopped my 79 K20 about 10 years ago and that stuff will be like new when the truck finally does fall apart.
Yeah i mastered the art of brake lines a long time ago. If the lines rusted in the fitting i just drill it out. This is absolutely invaluable also https://www.eastwood.com/universal-thread-repair-tools-sae-and-metric.html?gclid=EAIaIQobChMI1c2DhNTD8wIVH3ZvBB2t2w0wEAQYBiABEgJLD_D_BwE&wickedid=491598523420&wickedsource=google&wv=3.1
Plus if i did scrap an unobtanium fitting i can crank one out in the Mazak at work no problem.
Just making sure you were aware rusty... many folks here aren't as well versed as you with such things.
I've managed to save most things with my Snap-On thread repair kit and a full set of thread files... but that thread repair tool looks slick. I will have to remember that for when I stop spending money on the Bronco.
Roert42
4,941
Kintersville, PA
Ranger XLT
4.0 SOHC
I've had good luck with the Ni-Cop brake lines as well. Did them on my F-150. You do not need a bender to install them, which is great for someone who is new to this hobby or doing it out of necessity.
However, they are bright and shiny, so they stick out under your truck. If you get sloppy routing them it's obvious.
pjtoledo
2,953
Toledo Ohio
Fords
3.0 2.3
we wish you good luck with that :icon_thumby:
RustyShackleford94
Just some guy
355
IN
Coming from a true machinist, that thread repair tool is hands down the best thread repair tool on the market. They make on similar for internal treads as well.
broncc
561
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
I'm a firm believer the only way to save a car is my making it oily. Figured I'd still put down some rust primer and paint first...
sgtsandman
Aircraft Fuel Tank Diver
12,536
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I recommend Fluid Film. In a 5 gallon bucket if you have an air compressor. Hose that underside down! It will last about a year.
pjtoledo
2,953
Toledo Ohio
Fords
3.0 2.3
the guy that has done my Rangers uses less than 2 quarts per application. perhaps that's why it's called a film :dntknw:
RustyShackleford94
Just some guy
355
IN
ACF50 is my preferred anti corrosion. Pretty much because its in a spray can and its used heavily in aviation.
17,758
SW Iowa
My 2.8 did all that automatically.
When I pulled the engine the front crossmember had perfect black paint!
sgtsandman
12,536
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
It's cheaper in volume. I think I've used more than that in rattle cans on my trucks though. I get in all the nooks and crannies with it. I'm told the professional fluid film is thicker and more waxy. So, less may be more in that regard.
pjtoledo
2,953
Toledo Ohio
Fords
3.0 2.3
with rattle cans I usually apply wayyyy too much. it spreads over time, crept up the outside of a door about 3"
