What did you do to your 2019 and up Ranger today?
RumPunch
Law Enforcement
862
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Washed, pre wax cleaned and waxed the truck. (Only use Zymol products) Just about to turn 60k miles. Going to drive my 250 for a few days give this truck a look over before warranty expires. At least it looks good! Need some spray ceramic to help repel water but for now ok.
JohnnyO
Moderator Emeritus
3,109
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
On a second note you will need an alignment either way. If you take the bottom control arm just take a sharpie and mark the original settings on the cam bolt before you remove it so you can get it back to close.
I thought of that but wasn't sure what the odds would be of getting it back together. Like I said, I don't have the luxury of being able to finish it tomorrow.
Robertmangrum.rm
Wannabe Overlander
1,879
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
I feel you there. I done mine at the shop and was about to just slap it back together because I too only have 1 ride haha. But had a guy from the body shop next door recommend loosening the wheel nut. Bingo got it back together
JohnnyO
Moderator Emeritus
3,109
Pittsburgh, PA
2.3 EcoBoost
1.5"
@sgtsandman had a torque wrench big enough for the axle nut, it takes like 210 ft lb, but we didn't think that was thee problem as the lower control arm was down as far as it would go anyway and we even had a spring compressor. Bolts were still stuck on the coil bucket and we could have pried it out but the issue was going to be getting it back in either with or without the spacer.
Robertmangrum.rm
Wannabe Overlander
1,879
Tennessee
2.3 EcoBoost
305/70r17
Yeah I thought that too but it dropped quite a bit after I loosened it or basically removed it. Then screwed it back on about 2 turns. Also I do remember having to pull the bottom of the strut out first then drop the top out. And vice versa going back in.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
14,218
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
We're getting pretty proficient at tearing and reassembling your front suspension if you want to give it a go. Your call though. First thing is first, I would need to make sure I have the right size socket in the spindle nut socket kit before we went any further.
Robertmangrum.rm
Wannabe Overlander
1,879
Tennessee
2.3 EcoBoost
305/70r17
Did you try pulling the bottom of the strut out first then dropping it down?
sgtsandman
14,218
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Only the top since the studs were shorter up top.
Edit: The concern was we would only just barely get the strut out and in without the spacer. We didn't want to chance not being able to get the strut back in with the spacer installed.
Robertmangrum.rm
Wannabe Overlander
1,879
Tennessee
2.3 EcoBoost
305/70r17
Just be careful. Some people have separated the cv axle prying on the control arm. That's why I loosened the wheel nut.
Robertmangrum.rm
Wannabe Overlander
1,879
Tennessee
2.3 EcoBoost
305/70r17
Looks way easier. Wished I'd seen this before I did mine.
JohnnyO
Moderator Emeritus
3,109
Pittsburgh, PA
2.3 EcoBoost
1.5"
Thanks but I think I'll just take it to the alignment shop near my work.
JohnnyO
Moderator Emeritus
3,109
Pittsburgh, PA
2.3 EcoBoost
1.5"
In the middle of putting on a coat of wax since it's unseasonably warm today. Last chance before winter.
Blmpkn
Toilet enthusiast
7,141
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I washed mine the other day. She's got some good dingers in it now after all the wheeling it's seen recently.
Robertmangrum.rm
Wannabe Overlander
1,879
Tennessee
2.3 EcoBoost
305/70r17
Those are beauty marks. Haha
TexasDuck66
July Truck of The Month
25th Anniversary Merch
