Weird Anomaly last friday coming home
groovtubin
29
NC
Ford Bronco II
Almost home, 3/4 way up the hill here, it SPUTTERS, and i have ta put my gas pedal to FLOOR to make it home, mind you its not a mountain goat range but it IS a hill lol...Today i drove dwn road swashed it side to side driving, nothing, Anyone have this happen to them? Thx in advance..
superj
2,554
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
fuel pump? fuel filter?
maybe they need changing and are giving you a heads up?
rusty ol ranger
Im a Jeep guy now.
7,405
Michigan
177 CID
Check fuel pressure. Tank is downhill from the pump which is downhill from the engine. If the pump is getting weak and the hill was steep enough it might be just the perfect storm.
Im assuming its a 2.9. If its a 2.8 with a carb it could be carb/float related as well.
groovtubin
29
NC
Ford Bronco II
Thank you! N Thank u for your service to US of America SuperJ ! :)
groovtubin
29
NC
Ford Bronco II
Thank you!
RANGERICK
15
Vista Ca.
1987 & 1989 B2
Ford Bronco II
stock
Be patient and use a torque wrench when called for.
I have the same problem. On a slight hill I cannot get past 2000 rpms in third gear. New tank, both pumps and filters 45psi pressure.
groovtubin
29
NC
Ford Bronco II
Ok. Ended up it wouldn't start. Changed the FP regulator. No help. Pulled the hose off. Regulator . NO FUEL. Its at Garage. Course the FIRST thing outa techs mouth is COIL N TFI midule. Lol. Didnt tellem id alredi changed it. See what happens. 🤠🤪🤓
racsan
4,420
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
when mine is below 1/4 tank its that way, im using a inline summit efi pump in the framerail to pull fuel through the stock pump & push it to the engine. If I stay above 1/4 tank (1/2 to be safe) it never misses a beat.
RANGERICK
15
Vista Ca.
1987 & 1989 B2
Ford Bronco II
stock
I had one tech say the motor is shot. I need a new short block. WTH? Most techs are just throwing darts. It's hard to find someone who knows this motor.
JerryC
56
Tennessee
It's hard to find one that can fix anything without ODBII.
gaz
649
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
groovtubin,
The only thought I had is if the fuel in your tank was low enough, since the pumps is toward the front, it is possible that if the fuel level were low enough, the fuel had all sloshed to the rear. If on a steep enough incline, with little enough fuel, perhaps it was starving the in tank pump.
rusty ol ranger
Im a Jeep guy now.
7,405
Michigan
177 CID
Its possible but doubtful, ask for a compression check.
Truthfully the symptoms you describe sound like classic clogged cat.
RANGERICK
15
Vista Ca.
1987 & 1989 B2
Ford Bronco II
stock
I found a shop with techs that have that equipment. Only thing is they want my B2 for a month.
RANGERICK
15
Vista Ca.
1987 & 1989 B2
Ford Bronco II
stock
I pulled my cat and it was black. I read that this symptom indicates a clogged air filter and/or leaking, defective fuel injector(s)
rusty ol ranger
Im a Jeep guy now.
7,405
Michigan
177 CID
Possible....but theres also a multitude of other things that can make it run pig rich.
