2.3L ('83-'97) Weber 38 users
oblvnnwtnjhn
yfF2cUAQj&u7k#9g
Willys Jeeps CJ
Hi all, I have a 61' Willys Jeep CJ5 I am trying to dial in my Weber 38 on a mildly warmed over 2.3L F-134 inline four.
I see some Weber 38 related post in this forum, hoping someone with a 38 can share their jetting as far as mains, air correctors, and idle jets.
Spence
19Walt93
4,002
Canaan,NH
351
3"
235/55R16
The best way to decide which jet you need is to drive it some and check the spark plug color. I don't expect anyone here has done the exact swap you're doing. Good luck with your project.
Uncle Gump
Token Old Guy
11,869
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I use to work on a bunch of Weber carbs...
IDF... IDA and DCOE... typically and in a dual carb configuration most of the time. The rules are different when run as a signal.
I also did a bunch of Delorto work. Most of what I learned came from a book written Bob Tomlinson. The Delorto Handbook.
I think my copy is back in Michigan with all my other VW stuff. Search up book or any of Bob's weber info. I'm sure you can some baseline info there. A set of jet gauges and a jet reamer set will be priceless tools to have.
