Warm up after new Timing Chain and Cam
facemaze
8
Austin
2.3l
BirthTruckproblemsDeath
01 2.3l RWD Manual
Ive replaced the Timing Chain and Cam, I made it through my initial startup and it sounds like a gem. However I am curious about actually driving it. My but tells me to treat it like im breaking in a clutch.
But what do YOU think?
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
did the valve clearances remain in spec with the new cam?
does the Ford manual have a cam break-in procedure?
it's basically a mechanical flat tappet lifter setup, personally I'd keep the RPMs down for a couple hundred miles.
facemaze
8
Austin
2.3l
Yes and yes.
I followed the cam procedure, however I cant find one for a timing chain and I was curious about both repairs working in concert. Low revs for a few hundred miles was my thought too.
hanks
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I'd change the oil after a mild break in time as well. Probably not necessary but there may be a small amount of metal wear in on the cam.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
I broke my new clutch in by testing if a locker lets you do doughnuts .
It does indeed.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Youre right.
Its weird
And gross.
And ugly.
And diamond encrusted washers you princess.
I'll take my old sh*t made of iron and hate.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Pay no attention. No one will ever love him...
facemaze
8
Austin
2.3l
Thanks for getting my back.
Cant thank you enough for all the help you provided. The Ranger is running great. Im aiming to do the oil change and im going to new plugs, cables, and coil on Monday. I gotta retap my oil pan drain hole.
The next thing im looking to do is replace the entire exhaust system. I believe I can drop a newish one of a junker and rehab it then install it hopefully without welding. So please keep an eye out for that thread
please!!
