Wanting to paint interior panels....
mp3deviant721
24
Eau Claire, WI
2.3l of fury
To any of you who painted your radio bezel on your 95+ style dashes, did you remove the coating on the plastic before you painted or did you just scuff and shoot paint? Would it be a good idea to use an adhesion promoter on all of the plastic before painting as well?
Hooligan2c
Law Enforcement
Tobyhanna PA
4.0 SOHC
The first one I did, I scuffed it up, painted it and cleared it with about 5 coats and it came out great. If you do it that way I used windex to clean it after sanding, an ammonia based cleaner is good to use so it cleans it well in preperation for paint. You can also soak in in brake fluid to get the rubber stuff off first then paint it. Dont let it sit for days on end, it'll fall apart lol
Mark_88
228
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
ah, brake fluid...I just painted the metal parts on the inside of my truck...used windex too...didn't think about brake fluid...that stuff is pretty good at removing stuff though...:icon_thumby:
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Kind of an update, I started sanding it with 180 grit, the rubber coating is coming off alright. I'll have to sand it again to get it to 320 grit before I lay down primer and then paint.
killj0y
11
Edinburg, TX
2.3l 4 Banger
Fix it till its broke!
Lmc sells some paint that says it bonds to the panels vs laying on the surface. think no sanding required but is permanent and retains textured finishes.
