- Sep 21, 2007
- 654
- Wa, Bremerton 98310
- Ford
- Engine Size
- 87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
- 2WD / 4WD
- 4WD
- Total Lift
- Ranger 5" (2" suspension), BII 4" suspension
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 33"/4:10LS, BII 29"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
Kudos to The Uncle Gump,
I failed to correctly describe the process.
One relay IS for the low beams and the other IS for the hi beams. Thank you for identifying that point specific. Four relay could be used, I chose to use just the 2, since it is impossible to overload the 20amp relays or power supply fuse using legal 55w bulbs with only 2 loads/relay.
The combination of isolating the bulb power circuit with relays powered directly from the battery, and increasing the NEW wire gage can improve the supplied current to the bulbs by nearly 60%.
**That is alatta Mora powers Babi!**. You, will see the difference.
