Irokranger93
- Mar 18, 2010
- 0
- Michigan
- Ford
- Engine Size
- 3.0L
The only thing I have to say about Super Tech oil is the price. Comparing it to other oils of the same chemical make up, it's a little cheaper. Oil is oil, synthetic oil is synthetic oil. The molecules in these oils are basically the same, just a different size and shape. It's the additives that make the difference in any oil. Most of the general public doesn't understand what these additives are or where they need to be used. Without these additives, there wouldn't be a superior oil. Producers of oil lubricants have to meet standard guidelines for the type of lubricant they are producing. Most people that buy oil for automotive and other uses learn by trial and error or word of mouth what oil works best for them. Very few people read what additives are in the oil, and very few of those people know what the additives are or what they do. Oil doesn't really wear out. It either gets dirt mixed in with it or gets destroyed by heat. Temperatures have a great effect on oils. Cold can slow the ability to provide enough lubrication to moving parts and heat can scatter the oil, again not enough lubricant. Synthetic oils has a advantage over regular oils. Their molecules are a different shape and are not easily forced out of the microscopic grooves of the moving parts. Additives in these oils change the way oils behave. Without getting into high-tech lingo, there can be detergents, acid balancing chemicals, chemicals to let the oil flow more freely and other compounds to counter react the environment the oil is in.
The automotive industry and other mechanical industries have recommended lubricants for their equipment for a reason. Cheaper lubricants may not have the additives to counter react a environmental condition their equipment produces. This doesn't say that there isn't a better lubricant. It just says the lubricant they recommended has the correct properties needed to keep their equipment in good running condition.
In short, people want maximum lubrication for a longer period of time at the least amount of money. Super Tech is a good lubricant and meets or exceeds most manufactures recommendations. Common sense is my recommendation. Change oil and filter as recommended by the manufacture under normal conditions and more often if the conditions are exceeded
