PetroleumJunkie412
Official TRS EV Taunter
- Oct 31, 2018
- 6,565
- Dirtman's Basement
- Ranger
- Engine Size
- 2.9l Trinity
- 2WD / 4WD
- 4WD
- My credo
- Give 'yer balls a tug. Fight me.
Theeeeeeeeeeres my moment of zen. Well. Part of it.Ford's axle housings are usually pretty consistent. I would start by taking backlash measurements BEFORE disassembly as already stated, move the ring to the new carrier, and then put it in with that carrier's original shims in their original locations and recheck it.
The shims should have their thicknesses printed on them somewhere, you can also compare the two sets. It is unlikely they will be the same, but it's worth a shot.
If you cannot get the correct settings with the shims you have I'd just order a set of Yukon's build-a-shim seals and be done. Remember when fixing backlash add or subtract from each side as needed to place the carrier where it needs to be. When setting pre-load add to both sides equally.
I need to let that marinate a minute.
