wagoneer d44 vaccum disconnect
that_one_guy
The end of the Oregon Trail
Is there a way to get rid of it. Buddy of mine pulled it at the jy and didn't realize it was vaccum disco. Anyway around it? Thanks guys
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
Should be able to install a non disco axle shaft.
grapegoat
oregon coast
i just did a bunch of research on this and decided to stay away from it.
what you have to do is replace the 2 piece axle with a one piece from a hub lock waggy.
but either the inner or outer axle seal diameters are different, so thats a problem. gotta find a seal that fits.
and as for the diff cover with the pump thing on it, the diff housing is a lil wider than a normal 44. therefore normal aftermarket covers wont fit. that pump has to either be cut off and plugged, or a custom cover made.
get locking hubs
and after all that crap, you have a regular waggy axle. haha.
TexasDuck66
July Truck of The Month
