Will webber1985
- Aug 6, 2019
- Reaction score
- 0
- Age
- 38
- Location
- 03748
- Make / Model
- Ford ranger STX
- Engine Type
- 2.9 V6
- Engine Size
- 2.9l
- Manual
- 2WD / 4WD
- 4WD
Iam having votage issues got truck back from garge after having distributer put in. Was told to replace fuel filter because truck ran rough. But drove for awhile and realized wasnt fuel issue. The bucking got worse when I hit the horn. So i also tried turning lights on witch made worse. Same with heater fan. So any power draw on system makes truck buck and jerk bad. Took it back to garge to have alternator tested. Was told to replace so I did witch did not fix problem. So I cleaned all grounds up witch didnt help much if at all. Just this weekend my starter solenoid stuck open and wouldn't let starter disengage. So I replaced that. I cant figure this out and would love some suggestions on what could be causing this issue. Also truck has an internal votage regulator. Witch came with new alternator. Thanks for reading this and hope someone can help
