chrwilkins30
- Jul 8, 2010
- Reaction score
- 6
- Location
- Mishawaka, Indiana
- Make / Model
- Ford
- Engine Size
- 2.9
- Manual
After installing an 8.8 and getting regeared I drove the b2 for somewhere around 150 miles and then this vibration started out of no where. When I am coming to a stop and I really press on the brake it sounds like something is clicking and its pretty loud. I went through the front and re greased everything. At first I thought maybe the caliper clip popped out a little and was hitting the rim causing the caliper to shake. Is there a possibility that its something in the rear end.
I also considered the d shaft but why would it go 150miles then start to vibrate. I checked for the weights on it and they are still there plus why would it sound like some kind on brake issue. I have very good pedal pressure and it will stop great.
I'm going to open up the rear end tomorrow and take a look. Anything that I should look for instantly. If It is some kind of possible bearing issue what needs to be done?
Thanks, im going to start driving it again since I haven't for a month.
