rackdaddy
- Feb 24, 2019
- 0
- cabot Arkansas
- ford ford
morning,
03 4.0 a/t 4wd 110k , did timing chain guides, de-carboned heads, valves, pistons, replaced cranks bearings, cleaned wrist pins of burnt oil. The truck had jumped time, overheated, all the bad mojo at one time. valve seats held fluid, no visible bends, did have one gash one #1 but not deep. expected.
So after all that setting the timing (without ford tool) i have piston slap i believe. setting timing every reference shows tdc. then set cams, lock and tighten up. ran compression gauge for #1 set and tightened. should i have gone 10 degrees before tdc?
thanks in advance, again every reference has shown tdc.... alot of work for a noisy engine.
