Vacuum hose identification (hose is missing)
Splattercaster
Wisconsin, USA
Ranger XLT 3.0
Hello,
I am dealing with a mouse nest that got sucked into my engine after the truck sat for a while. '93 3.0l. Immediately downstream of the mass airflow sensor is a nubbin for a vacuum hose, but no hose is present. When the hole is open the truck will not stay running, when it is sealed (as in the pictures, sealed with a zip tie and chunk of rubber glove) the truck runs 'as normal'.
I feel dumb for not being able to determine what or where this hose should go by looking at my manuals or vacuum diagrams. Any help?
Thanks in advance!
Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
18,692
Wellford, SC
6"
That should have a hose going to the nipple at the base of your oil fill neck.
Here is the vacuum.hose diagram for 93, 3.0l. It doesn't show that hose.
And, in case you need it in the future. The belt routing diagram sticker.
Splattercaster
Wisconsin, USA
Ranger XLT 3.0
Thank you so much! I wonder why they didn't include it in the vacuum hose diagrams.
Uncle Gump
Boomers gotta Boom
14,946
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I've never owned a 3.0L...
But that isn't a vacuum hose. It's a fresh air inlet for the PCV system. This explains why it isn't on the vacuum diagram.
It also shouldn't be pulling a vacuum on the nipple... not like a manifold vacuum source anyway.
But with it left open... it messes with the values sent to the ECM from the MAF. It's allowing unmetered air into the engine.
mtnrgr
448
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
As mentioned it's a fresh air hose for the engine. It connects from air intake hose to the valve cover. Here is a picture of mine, zoom in and you will be able to see it. Those hoses are available at any part store. Years ago when it needed replacement I bought a hose from a auto parts store, don't recall if I got a oil, fuel hose. What is in there it works as it should.
Splattercaster
Wisconsin, USA
Ranger XLT 3.0
Here's what I found. No apparent location for the hose to attach. The valve covers are leaking like crazy and the former owner didn't have an oil cap for years, he was using a rag. Clues to a bigger story I suppose. Replace the covers maybe? They say "3.0l V6". I am about to replace the gaskets otherwise.
mtnrgr
448
California
31x10.50
That piece is busted off, and will need a replacement valve cover. Rangers with 3.0 engines might be rare in your area. For the correct valve cover you will one from a 91-94 3. 0 ranger. Ranger 3.0 95+ has that nipple in a different location..you can make it work if all that's available.
Taurus from 92-95 will be the same. I would find a good pair of valve covers..the driver side may be damaged also. A few months ago I replaced my valve covers, and gaskets. I got them from a 94 3.0 Taurus as no 3.0 Rangers were available.
I would replace both valve covers. I use felpro for most gaskets on my ranger. Definitely wait until you find replacement valve covers before replacing the gaskets..no need to do the job twice.
Redav72
Aurora, IL
That's a terrific looking engine bay. Would you be able to post some pictures from all sides? I'm in the process of rebuilding a '94 3L and I'd really appreciate reference pictures.
Rick W
October Truck of The Month
25th Anniversary Merch
