V8 Swap Tranny Possibilitys Gearing
mhughes165
9
302
Manual Transmissions 1st 2nd 3rd 4th 5th
Bronco 3 spd (6 cyl) 3.41 1.86 1.00
Bronco 3 spd (8 cyl) 2.99 1.75 1.00
NP 435 6.69 3.34 1.79 1.00
T-18 6.32 3.09 1.69 1.00
Toploader (Close ratio) 2.32 1.69 1.29 1.00
Toploader (Wide ratio) 2.78 1.93 1.35 1.00
Toploader (Overdrive) 3.29 1.84 1.00 0.81
ZF 5.72 2.94 1.61 1.00 0.76
NV4500 (Dodge) 5.61 3.04 1.67 1.00 0.73
Automatic Transmissions 1st 2nd 3rd 4th 5th
Bronco C4 2.46 1.46 1.00
C6 2.46 1.46 1.00
AOD 2.40 1.47 1.00 .67
AOD w/ low gear set 2.84 1.55 1.00 .67
AODE/4R70W* 2.84 1.55 1.00 .67
700R4 3.06 1.62 1.00 .70​
mhughes165
9
302
a AOD with a low gearset is actually a hybrid of the early non computer controlled AOD, and the later AODE/4R70W, essentially its the guts of a later electronically controlled AOD in a older non computer controlled shell....i personally have never attempted the conversion so i could not tell u what all needs done, however if u goto a show that specializes in transmissions, they should be able to build it like that for u, but for the money ud spend on that id just have them custom build it with much lower gearing then that.....
