V8 Exhaust Question
markinms
17
MS
5.0L EFI
4"
31 X 10.5 X 15
Duty, Honor, Country
I'm getting ready to install a set L&L headers on my 5.0L BII. Very well made and come with 2.5" collectors. Went to arrange exhaust system install with local muffler shop and the guy I spoke with "strongly" suggested I reduce from 2.5" to 2.25". My goal was to run 2.5" from the collector to a universal cat, to flowmaster muffer, and out to the back of the vehicle.
What do ya'll think? Does it make any sense to go to a smaller pipe?
Thanks for any feedback!
Mark
ericbphoto
Overlander in development
16,548
Wellford, SC
6"
He probably knows more about exhaust than I do. I have read many times in recent years that with exhaust systems, bigger is not always better. Apparently, you need to keep it small enough to maintain good exhaust velocity for scavenging. That's most of what I've learned. A quick Google search brought up this page that applies some science to the issue. I'm sure others will chime in soon with more info and plenty of opinions. According to the article I referenced, I would guess that a stock 302 would be right on the edge between 2 1/4" and 2 1/2"
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
I used a 2 1/2" single system on my 13.8 second, 302 Mustang and on my almost stock 351 Ranger with a Jones Max Flow muffler- it's like a Magnaflow for way less money. Dual 2 1/4" would be enough for a 6000-6500 rpm 302, velocity and torque would be higher with dual 2" for a more truck oriented engine.
8,369
Whats the collector outlet size?
As long as you are equal to or larger then doesn't matter
The size and length of the pipe from each cylinder and the size of the collector pipe decides the RPM band when you get scavenged power from the exhaust manifold/header design
As long as you don't go smaller after the collector it wouldn't matter, unless you are also looking to do "X" or "H" scavenging as well, then you would want to stay with collector size pipe
markinms
17
MS
5.0L EFI
4"
31 X 10.5 X 15
Thanks for the feedback! Collector size is 2.5 inch. I think I'll stick with my plans for a 2.5" exhaust system and override the muffler shop dude.
Also, thanks for tip about the less expensive muffler. I'll look into that.
Mark
ford4wd08
510
Alcoa, TN
2.8 V6
I would like to see pictures of this B2 5.0 swap.... I don't see many of them on the forum!
markinms
17
MS
5.0L EFI
4"
31 X 10.5 X 15
Here ya go, I kept a complete photo history of every task completed for the swap.
43069
ford4wd08
510
Alcoa, TN
2.8 V6
Looks awesome! I might start collecting part for a swap someday. Looks like you kept the AC box as well?
How did the AOD fit? What transfer case? Do you have a build thread?
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
If you're talking about a 2 1/2" single system, I agree, a dual 2 1/2 will lower exhaust velocity and may hurt bottom end. It will likely be louder, too, and I'm not sure where you'd put a dual 2 1/2 system under a Bronco II, please don't run it out in front of the rear wheels.
My Ranger didn't have a heater box when I got it so I used a Vintage Air system, you're evap case really crowds things.
17,775
SW Iowa
I just have 2-1/4" duals on mine, I am happy with how it sounds.
Junk Collector
Truck of Month
4,789
Rapid City SD
I have 2.5" single on mine, a Y pipe that goes into a single in/single out Flowmaster. Sounds good.
I suspect that there is a fabrication and/or muffler selection related reason why he said to go with 2.25".... maybe it has to do with where the inlet and outlet are placed on the muffler itself, I wanted a specific center in/center out muffler recently and it was only available in 2.25". I can't imagine that 1/4" makes any difference.
FWIW Roadkill/Engine Masters did a series of videos on exhaust size, X/Y/Y/etc crossovers, headers, and stuff a while back and I was was left with the impression that it doesn't matter as much as you'd think it would in most cases.
markinms
17
MS
5.0L EFI
4"
31 X 10.5 X 15
My Ranger didn't have a heater box when I got it so I used a Vintage Air system, you're evap case really crowds things.View attachment 43071
Very nice!
markinms
17
MS
5.0L EFI
4"
31 X 10.5 X 15
The AOD fit fine, although a bit snug in there. I used the stock transfer case with an Advance Adapters AOD to BW1350 adapter. I never created a thread while I was doing this.
ford4wd08
510
Alcoa, TN
2.8 V6
It is never too late. Would love to see a thread!
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
I used a C4 because I had one that I had driven and knew it would be an easy rebuild. I've never built anything with an automatic transmission and didn't know if I'd be able to stand it, if I decide to swap in a T5 I should be able to sell the C4 for a small profit.
