V8 Conversion Headers
joey74
16
Vincent Ohio
I bought some stainless shorties for $140. A little dent in one spot and it should bolt up. Drivers side is pretty much In place. I'll be back with photos for the
passenger
It says you have a 99 . do you know the part # and where did you buy them. what motor mounts did you use and have you got stock cab mounts? Thanks
Hrphilipson
Arkansas
Anyone tried these Patriot Clippster Headers H8433-B on an 86 4x4 by chance?
89Greenie
Northumberland PA
If it don't fit, We'll make it!
Hey! Was wondering if anyone had any word on a possible set for a 351C swap, if not I can weld up my own possibly
Chris86ranger
4
410**MUstang
86 ford ranger
If you have anything other than a 302, your out of luck. Even some of the 302 offerings can sketchy fitment wise, also the more power you make the slimmer the offerings get. Once you need more than a 1 5/8 primary tube your s o l.
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
Hey Greenie, I went with Sanderson shorties, although I went with a K member for the rack and pinion steering to get rid of that bothersome steering box, which really screws up everything!! Constructed a 2" x 3" tube frame from the cab forward. It certainly wasn't in my build plans but after many measurements and try fits with the "C" block I really couldn't see any other way to git er done. And happy I did so, it gave me more options than I expected. Good luck with your build, my 351/408C is a gas to drive! :yahoo:
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
My guess is no. I am placing a 351C into a 91 as another current project, and seems that running just stock exhaust manifolds is enough of a challenge for these trucks. I am sure making your own will be the best bet or going to a custom shop for something exotic. cheers and happy hunting/building. if you do get a set that works, please post up a pic or two, would love to see what you do. ps, is your front frame boxed in for more strength? added room problem there also.
Kirby N.
March Truck of The Month
