v2 Bronco 2 build
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Well this is version 2 of my old thread, since the whole process turned 180degrees the other direction, and the 88 is being brought back to life!
What's going on:
- 2.9 engine pulled
- 2.9 cleaned and rebuilt
- 2.9 painted
- frame cleaning/derusting/painting with tractor paint
- body work and paint
- interior stripped and replaced
- chop top? Roll cage?
- 4.0 flywheel, clutch, starter?
Here are the pictures!
Pbheadshots
Shelby, NC
1984/8 mix
2.9
By the end of the weekend it should(fingerscrossed) be painted both frame and body. The it's off the the engine cleaning.
4.0B2
151
Walls, MS
4.0 v6
subscribed
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Roll cage and chop top. FTW!!!!
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Well damn. I was pulling the b2 out of the carport today and stupidly let a string of wiring harness' drag the ground and it got pulled by the tire and broke a few and tore wires apart. Are the molex connectors used a universal size that can be bought individually or do I have to buy a whole new harness, or junk yard one?
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Started to paint the frame! Look at that gloss!
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
May I suggest putting a whole 4.0 setup in there. I would highly recommend it.
88B2EB
6
Detroit, MI
2.9L, 2.3L
I used 'Vintage Connections' when restoring my motorcycle harness. Don't recall if they make OEM Ford replacements but at least it proves that sort of thing IS out there.
Keep up the good work:icon_thumby:
Pbheadshots
Shelby, NC
1984/8 mix
2.9
The problem is finding a 4.0 to use. The only one I know of was a buddys truck that he rolled a few days ago, and other than that no scrap yard has the whole setup for a good price that is reasonable. I may try bartering with my local scrapyard to trade a 2.9 and a 2.8 for a 4.0 with everything on it and low miles.
I'll keep looking! Thank you for the compliment!
Pbheadshots
Shelby, NC
1984/8 mix
2.9
More eye candy: will update a caption!
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Lookin good! I say go with the 2.9 it will be simple and you won't have to look so hard or pay as much for parts! Besides the 2.9 has more low end torque than the 4.0 don't it?
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Imma do that.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Definitely... Not.
The 2.9L is a decent motor, but with the 4.0L available (and as easy a swap as it is), I'd be much more inclined to drop that in there instead. The gas penalty is usually less than 2 MPG (depending on your prior driving habits it could even be about the same MPG too).
Pbheadshots
Shelby, NC
1984/8 mix
2.9
Definitely... Not.
If I can even find a 4.0 to put in it!
No members online now.
