- May 14, 2018
- 1,085
- Western Mass.
- Ford/Ranger XLT
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- Tire Size
- 225/70/R15
- My credo
- If it's not broken Don't Fix It!
How can you figure out what the proper resistor you need is when using LED bulbs?
Issue: 3rd brake light staying on dim but only when the ignition is on.
I just ordered 2 more gaskets for the light so I can remove it and test one time and one to insert the proper resistor if that is the issue.
Testing will consist of hooking up the original and seeing if it is on, If not it needs a resistor, if yes then I need to find the bad ground.
The real question is how do I know what resistor I will need to help break the grounds contact just enough to shut off the light but still allow it to make a connection when the pedal is pushed? I know nothing about resistors and there ratings so some guidance is needed.
