Upgrading 89 RABS to 4 Wheel ABS
Nez'sRanger
68
Pennsylvania
2.9L V6
Is it possible to upgrade an old 89 RABS to the later 4 Wheel ABS?
I would love the added braking quality/safety, but I fear the newer abs controllers may in fact be tied into the OBDII system.
I'm interested in upgrading the front discs to the dual piston calipers from a 95 (as well as a rear end swap at some point), so I could have all the abs wheel sensor mounting points installed at some point.
Thanks for the input!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
do you have a 35 ?
There are several layers of complexity.
But a system from a say ... 93 bronco is stand alone. You will need to do a late model d35 knuckles d swap with 4wabs or a abs d44 knuckle swap.
The explorer ttb and later ranger ttb 4wabs are bolt In stand alone as well. Provided your truck has the rear tone already ..
Nez'sRanger
68
Pennsylvania
2.9L V6
I believe my ranger has the Dana 28 front.
I didn't see that this influenced the knuckle swap, but good to know now!
At this point, the rear end is stock too, so I'm just doing my homework before buying anything.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I use them for burnouts....drifting and 4 wheeling...in place of a front locker.
But never for abs brakes 🤣....
