sexybluelady
- Oct 16, 2008
- Reaction score
- 11
- Location
- springfield, ma
- 1988, 1994, 199
- Make / Model
- ford, mitsu, do
- Engine Size
- 2.9
- Manual
Does anyone know of a manufacture that has a kit close to the old Superlift Superunner Steering kit sup1134?
Or know of a place that sells something close to these shocks and setup and I can fabricate up some brackets to bolt it all up. I really want to tighten up my suspention on my truck. I have replaced and upgrade the entire front end. From pivot bushings, to ball joints, pitman arms, drag links, coil springs, coil spring buckets, everything has been replaced, even the rag joint. But I still want to tighten it up a bit more. Thanks. I have a 88 Ford Ranger 4x4. Thanks everyone.
Suspension Accessories – 1983-2011 Ford Ranger 4×4 – The Ranger Station
When you lift your 1983-2011 Ford Ranger, there are some suspension accessories that you may need. Even if you've bought a new suspension kit, it may not come with a dropped pitman arm. Extended Brake Lines: You'll need longer brake lines if you lift your 1983-997 Ford Ranger 4x4.
www.therangerstation.com
