Wanted Upgraded 140amp alternator for 2.9 ranger.
sexybluelady
11
springfield, ma
ford, mitsu, do
Looking for a bigger alternator, to replace the stock alternator. I have a 2.9L first gen ranger. Thanks
Paulos
210
North Carolina
1987 STX
I followed this guide (for the most part) to put a 130A alternator in my '87 Gen1 Ranger.
sexybluelady
11
springfield, ma
ford, mitsu, do
Thank you, but the question is do you have one for sale??? That's what I actually need and why I made this post....
Paulos
210
North Carolina
1987 STX
My point in directing you to the guide was that it's not as simple as installing a different alternator (perhaps you already know this?). A Gen1 Ranger with AC has a maximum 80A alternator available, and the wiring in the charging system does not support anything higher. As far as I know, there is not a direct bolt-in replacement available (at least not anymore) because the original wiring will burn up if you try to pull 130A through it.
I bought my 130A alternator from a local wrecking yard for around $35. Fits a '95 Mustang. https://www.rockauto.com/en/catalog/ford,1995,mustang,5.0l+v8,1134188,electrical,alternator+/+generator,2412
The guide lists the other parts you would need.
Years ago when I wanted to upgrade my alternator, the only direct fit "upgrade" I could find was at NAPA. The problem was, it was very expensive and it was still a Ford 2G alternator. After researching the issues with the 2G alternators I decided it wasn't a good idea to have a 130A version of it, so I went with the 3G Mustang alternator mentioned above. Here's the link to the NAPA direct fit 2G alternator.
I'm sorry if this isn't any help.
sexybluelady
11
springfield, ma
ford, mitsu, do
Yes I am fully aware of that swap and that guild, but that doesn't help me out in my current situation. I listed a post in the wanted section looking for someone that has a used upgraded alternator sitting in their garage. I also live in the North East and most of the yards around me have been picked dry or everything is junk and rusted. Hence why I made a wanted/looking post. Thanks for your help, but I'm still in the same situation.
No members online now.
