Upgrade 2010 2.3 Ranger
AyAnthony702
4 Banger
So I'm stuck on my truck right now. I wanna add some horsepower to it. I'm not looking for a lot of hp. Are there upgrades for it like comp cam or comp headers?i know I can swap in a 302 or 4bt but since I have a obs2 it would be hard. Is there any swaps that will be easy with a 2010 or upgrades that can amp up my truck a little. Thank you
Soledad
2.3L Duratec
You might try asking on the turbo ranger site but I know that MSDS makes a header for the 2.3 Ranger Duratec's, I just don't know exactly for what years. And Crower makes camshafts for this engine but again I'm not exactly sure for what years. And I want to say that Bullydog or SCT or Superchips or one of them has tunes for the 2008+'s but once again, I'm not 100% sure on that. I think you can go with SCT and a custom tune but I'd double check that.
Hopefully others will chime in but that should get you started searching.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
645
Central Indiana
We've talked about all of this before in your several previous threads about the same topic.
You have a lifted truck with big tires. Adding cams can increase power, but it's going to do it higher in the rev range, which means it will make it feel slower off the line (where rpms are low), and faster on the top end. That's the opposite of what you want in a truck with big tires. It's also a pretty in depth job best handled by experienced mechanics/wrenchers that requires more time and special tools. That's not cheap.
If you're sticking with the lift and big tires, you want more torque, not necessarily more hp. The only way you're really going to get significant torque gains from a 2.3L 4 cylinder is a turbo setup, and that's going to be completely custom. You can go back and review your previous threads about turbo duratecs to refresh what all would be required to make that happen.
If you want cheap-ish gains from small, bolt on mods you're down to removing the clutch fan, getting an underdrive pulley, and having a custom OBD2 tune written. MSDS does make a header for our trucks, but the factory manifold is essentially a cast header, so I'd be surprised if you saw real gains from a header install other than your wallet and truck being lighter. If I remember correctly, you're in the Vegas area somewhere, so removing the clutch fan, and reducing cooling might not be a great idea unless you also get the tuner to lower the trigger temp for the factory e-fan. You can do the tuner without removing the clutch fan, but you really shouldn't remove the clutch fan without a tuner.
Dirt addict
What final drive ratio are you running? 3.73, 4.10, ? Depending on tire size, type of driving you do, a gear change may help with torque at lower rpms.
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
please review the first line in post 3
Dirt addict
I just got my 2010, 2.3 manual 5 spd back from the mechanic. I had a ford racing 4.10 ring and piñon put in. It did have a 3.73 ratio. I bought it used, with 235/75/15 tires and steel 15" wheels. It was anemic prior to the 4.10. On inclines I needed to down shift to 3rd on some hills on the freeway. It is SOOO much better. I was worried that 1st gear would be too short. Not an issue. I'm calling it a win/win. I'm very happy with it. It seems to have gotten a few dings while at the shop, but I could be wrong...definitely came back with some grease smears on the sides.. Grrrr.
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
3rd gear on the highway? Wow
My moms 03 2.3 has 235/70tires on edge wheels and 3.73 gears, it feels just fine and wont need more than 4th gear to climb inclines. Maybe 3rd if traffic is slow. Its close to 200k miles too
justknah
Have 03 ranger clutch hose pops off
Sent from my SM-T700 using Tapatalk
justknah
All new hose ,and all but as soon as try to pump clutch to bleed it just pops off? Help please
