Up grading my 2.8 l v6.
Garyeason1961
Utah
Ford Bronco2
I have a 1984 Ford Bronco 2 with the 2.8 l v6. I am upgrading and I'm in search of a distributor to replace the sock one. Nobody has the Cardone distributor. Everywhere I've looked no one can get it. Is there an alternative to that distributor?
Junk Collector
Truck of Month
4,798
Rapid City SD
Junkyard from a Mustang II, Pinto or already converted Ranger/B2 is going to be your only source at this point unless you get lucky or they start making them again. They have more or less been unavailable for about a year.
Garyeason1961
Utah
Ford Bronco2
Thank you. I will start checking junk yards.
Garyeason1961
Utah
Ford Bronco2
Is there an availability for parts to rebuild that distributor when I find one?
Garyeason1961
Utah
Ford Bronco2
I would also like to agree to a five-speed manual. I currently have a 4-speed manual in it. That's what it came with. If you have information on a good trans swap it would be much appreciated.
Junk Collector
Truck of Month
4,798
Rapid City SD
Looks like you can get some parts for the distributor. With how this situation has unfolded recently, I wouldn't plan on being able to get any parts for it in the near future.
Curious if anyone has tried to use the TFI distributor with an MSD ignition box like this thread suggests you can on a V8:
Then all you need is an appropriate carb or modify the one you have.
Junk Collector
Truck of Month
4,798
Rapid City SD
FYI the 5 speed swap has been done a million times, check out the Tech Library link above and search through the Transmission section on the forum for details.
Garyeason1961
Utah
Ford Bronco2
Thank you for the information. I'll look into both.
