U joints
professor229
77
Minnesota
Good morning.... I still have some noise coming from the back end and am pretty sure that it is the U joints.... and with 106,000 miles on it, the time has come... I have NOT replaced U joints in anything for over 30 years... probably closer to 40 years ago.... so I need a refresher and advice....
I know that the drive shaft was marked to keep the balance integrity the same.... with a scratch or paint; whatever... I know that a good six point socket/wrench needed to be used so you didn't round off the four bolts.... and I know we used two sockets, one larger for the u joint to sit on when you pound on a smaller socket on the "other side" ..... after removing the retainer clips.....
Then the replacement was much the same using the two sockets to tap in the new u joints and making sure the retaining clips were seated and secure...
Now for some questions.... Are both the front and rear U joints the same on a Ranger? Do I need to replace both? Is there a brand name better than others? Is there a brand name to avoid?
Should I try to replace the front seal on the tranny housing and can this seal be carefully tapped in to place? Is there a back seal that needs to be replaced? What else am I missing?
Thanks for holding my hand.... LOL... it is much appreciated....
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
12 point bolts, 12mm
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Something else to consider is buying or renting a ball joint press. It makes short work of the u joint replacement task.
professor229
77
Minnesota
I saw the picture of the ball joint press..... and most videos show the DIY guys using a large vise and two sockets like we did back in the 60s...... My problem is that I don't have access to a large vise and I don't think my vise has a large enough opening to even consider this.... and, I hesitate "pounding" on the socket to unseat the u joint.... although that is the way the chief mechanic where I worked did it all the time.... but I ran into other problems with this too.... I found so much contradictory information about ordering these..... and I am probably overthinking this again... but when I research to be sure, I found that at least two companies have clearance u joints because they are out of business and selling them off..... and here is a link as well as a picture of what I found.... https://www.rockauto.com/en/catalog/ford,2004,ranger,3.0l+v6,1427958,drivetrain,universal+joint,2392
I like to go to rock auto to get a parts number and then google it.... but as I said, I get some conflicting information.... and please consider... This is a $500 ranger and I don't want/need high quality parts for it..... and yes, there is a budget.... I understand you get what you pay for... I tried to find PDQ which is the cheapest listing.... so I could find their application chart to confirm these are the correct u joints and almost ordered two.... but... then, later, I found a few sites that listed two different numbers for the front and back u joints..... confusing.... The GMB listing a little below also is more/less a clearance deal because I cannot find an application chart online, for them either and will spend some more time today looking.... and yes, I blame SOME of the parts sites online for being so vague in their information.... and in rock autos case, you cannot even contact them to ask.... so I am hesitant to order two of those "el cheapos" from them.....
So... if you have been there/done that... maybe you can help.....
Are the u joints in the front and back of the driveshaft the same size? (this is a standard 2004 Ranger XL with a seven foot box)
PS.... One other thing I am considering..... There is a U Pull it Parts outfit near.... and if the price is right, why couldn't I go and pull a drive shaft from one of their junkers and slap it in mine? And there is one other question.... I have the seven foot box on mine.... and most were six foot boxes.... will a drive shaft for a six footer even fit my seven footer? Does that question make sense?
and just one more thing.... isn't there always? I bought a chipped key blank on Ebay.... my local hardware store cut it for $3.... it opens my door locks perfectly... I followed the online instructions I found to program the key... basically, insert an original key, turn on and off the ignition... repeat within five seconds with my second original key.... and within ten seconds, insert the newly cut duplicate.... the red security light should stay red for three seconds to tell you it is programmed..... Simply... it didn't work and yes, insanity because I tried a few more times... there is another website that tells you to insert an original and turn on and off the ignition many times and then insert the key..... are they for real??? Anybody have any experience with this or is it just hokey?
Thanks.... appreciate all the comments.....
sgtsandman
Aircraft Fuel Tank Diver
12,641
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The u-joints on the rear drive shaft are the same. If you have 4X4, the front drive shaft uses different u-joints.
The last time I did u-joints, what the parts store had listed wasn’t correct. I had to bring the old ones in to make sure I got the right ones. If you only have one vehicle, that might be a bit difficult unless you can borrow someone else’s.
professor229
77
Minnesota
Hey!!! thanks.... I went back to Rock Auto to look/think about some of their listings and think I have this figured out.... Please check out the attached shot of the Rock Auto listing... The top/first entry is for 4WD (and I don't have 4WD)....... and check out the part number..... Then the second, third, and fourth listings all say for "rear" or "all joints" and have nothing to do with 4WD...... Do I have this right? Thanks again for the explanation... I might just try this myself....
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I swapped to a one piece driveshaft. Ordered U joints from rock auto. I got the good ones. Works perfect, no problems there.
I used a large c clamp to press em in.
professor229
77
Minnesota
That is exactly what I intend to do as well.... My Dad's head mechanic had a way with U joints.... it was called a couple of sockets and a hammer....... I also have a very large C clamp..... and my only fear is getting too aggressive.. and breaking the drive shaft..... Anything else I should watch out for?
don4331
1,346
Calgary, AB
5.3
7' box driveshaft is 6" longer than one for 6' box; and the one for a SC is 8" longer than 7' one, so no mixing there.
I use a 12 ton press with sockets and never busted a driveshaft (may be bent a little, but the press fixed that too). I tried large C clamp and just bent the clamp (ball joint presses are significantly stronger than my C clamp).
Keys need to be programmed with Forscan or equivalent (some hardware stores have ability to clone keys). My solution is to remove the bottom cover of the steering column, put the coded key there. Reassemble. Then use normal uncoded key in door/ignition. The coded key is close enough to the sensor, that it works.
professor229
77
Minnesota
Hey.... thanks for the great information!!! So here is what I did and am going to do... Fed Ex just emailed that my U joints will be here on Wednesday from Rock Auto.... and I suspected that this driveshaft was unique because of the 7 foot bed length... and have dealt with this before. There was significant damage to the passenger side of the box when I bought this as a project, and my plan was to remove the side panel of the box and replace the entire side of the box...... Then I found out how rare a seven foot box was and the replacement panels/facade are no longer made, and the only hope was to find one in dealer stock..... which is impossible.... I instead got out all my dent pulling tools including the one that worked the best... my toilet plunger... and went to work... I learned and researched a six foot box to replace the seven foot box but that was a can of worms too... so I suspected that this drive shaft may be longer.... and now I know it is..... and I DON'T want to screw it up and try to find a replacement driveshaft.... it's call paranoia.... controlled paranoia... and considered going to U Pull It Parts to get a used driveshaft but there are no seven foot box Rangers..... so when the u joints come in, I am going to fall at the mercy of my local mechanic who has been more than good... and pay him to do this... This is one of the last major projects to be completed on this $500 project truck and I don't want to screw it up now. I have well over 200 hours of time in the rebuild.... I no longer own the tools I had from my youth in the 60s...... and it is time to punt on the idea of doing this myself....
As for the key... I tried one more time and made some progress.... and this is not a big deal... I have two working keys for the Ranger but on my other trucks that pull boat trailers, I hide a working key in a magnetic box under the rail of the box just in case... I also keep a working key in my tackle box, again, just in case.... there's that paranoia thing again. Backed the Ranger into the work stall last night and cleaned up the box completely and prepped it for a coat of Rustoleum epoxy coating that will be applied this morning and for laughs, I tried to program my new key again... and yes, I heard back from the website guy who listed how to do this.... and he more less bailed out, giving me three possible scenarios why the process failed.... ... but I did the insert two keys in succession and then the new key and this time, the new key turned the starter motor, but the ignition must apparently still be disabled because it did not start... I repeated this process again and left the two initial original keys on "run" for four seconds each instead of the one second advised... and that was the difference... so the sensor for this is under the steering column? Would it help to maybe put the newly cut key down there while inserting the two originals?
I also got a request from the blank key Ebay seller for feedback and have no idea what to leave for feedback but did contact him and told him that of the three choices, it would not be positive.... at best neutral, and at worst, negative.... He has a disclaimer near the end of his listing saying you may need the Ford dealership to program it OR a locksmith..... and that isn't going to happen.
So this morning, I will apply the box coating.... and later this week I will be contacting my mechanic and making sure he can/will install the U joints....
I have used the Ranger to pull my small 12 foot boat trailer to the lake (five miles) and back several times now... the "chirp" is almost gone but I can still hear a whizzing sound and a heavy chirp when I pull the loaded boat trailer up the ramp when I am done fishing.... but once in the parking lot, the chirp reverts again to the "whiz" sound..... and I sure like the Ranger..... compared to my 1995 Chevy W/T...... The trip to the lake is low speed back streets more/less so I am never going much over 30 mph.... but I do want this resolved....
Again... thanks for the advice, information and suggestions.... it sure shortens up the research part of all this....
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Getting a driveshaft made is not a big deal nor astronomical. Driveline shops are few and far between, but do exist. They can whip you up one for probably $500-$1000 fully assembled and balanced.
The accident may have tweaked the frame and/ or driveshaft. I'd check that out. There are shops with frame straightening machines too.
professor229
77
Minnesota
It is very possible that the frame was bent but I was told that the truck slid into the ditch, went on the passenger side and it was simply pushed upright.... lots of damage to the passenger side box and front fender... no damage to the door... But this is not a big deal.... so will get the U Joints installed and see how it goes.... This morning... welded in a new ratchet strap bracket in the box.... two bolts held it in place... both broke off.... easy out is a pain so went with welding it back in place... and the set up for the Rustoelum pro roll on "stuff".... not too bad but would rather spray the box... two coats... video comments I watched said they struggled to get two coats on and didn't have enough... not a problem with a Ranger and had some left over so I rolled some on the boat trailer fenders..... came out great... Took about two hours to get this done.... and now will leave it in the garage for a couple days to cure...
The green in the pictures it the "patch".... marine glue around the perimeter and self drilling screws to hold it in place while the glue cured... ground off the heads of the screws the next day.... and wire brush on a drill to clean up the glue that squeezed out.... The patch worked well... and if I didn't tell you, you would not notice it in the box....
Before/after pictures.... and will probably have to buy a rattle spray can of the stuff to touch up some spots where the roller missed.....
It was a good morning....
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Honestly I though it was much worse based on your description lol. Looks good, nice work. I say yea try the u joints and if that don't work, then may take it in to see if its bent or out of balance. If so, then get it repaired or a new one....I've dealt with driveshafts alot🙄.
17,822
SW Iowa
For my V8 swap longbed I hunted down a driveshaft from a later Supercab and had it shortened, like $75 to have a shaft shortened and rebalanced. Earlier supercabs had a two piece shaft with a carrier bearing which I wanted to avoid.
The snag is when junkyards move trucks with payloaders they screw up the rear diveshaft with the forks. So you basically have to happen upon a truck where somebody had pulled the trans before they junked it so the driveshaft is in the bed and thus not crunched.
professor229
77
Minnesota
After researching the uniqueness/rarity of a seven foot box Ranger driveshaft, I decided to farm this one out even though I had the Rock Auto U Joints in my possession already.... and talked to the local mechanic that has done some work for me when I was too busy etc.... and he agreed to install them... we didn't discuss price.... but he has always been reasonable and I tend to be living in the 1960s......so yesterday I loaded my pedal bike in the back of the Ranger and dropped it off at the mechanic's business parking lot at 4:30 a.m. and rode my bike home... (He doesn't want customers to leave vehicles in the parking lot overnight..... catalytic converters... enough said?) Got the call at 4 pm that the Ranger was done.... rode my bike back and paid $238..... for the install... two hours labor at $100 per hour, shop supplies, miscellaneous, grease, and tax..... I guess that is about what you should pay these days; I suspect that the U Joint removal took some time and "heat".... but I will ask for an estimate next time... I was VERY pleased though as I diagnosed this problem and it was the U Joints.... The mechanic said one had a cap that was completely rusted along with dry and rusted needle bearings.... I was glad it was that because the next squeak/chirp guess was probably going to be a rear axle bearing.... Anyway... drove off... no noise... perfect.... and the $500 Ranger is now mechanically sound and my next mission is to find some snow tires for the rear... or perhaps like last year when I lucked out finding four nearly new Wilderness tires for my Chevy for $200 at the big, end of the year swap meet at the state fair grounds.... I am finding out that "snow tires" are becoming a thing of the past too..... Anyway..... I think I could drive this Ranger to California and back if I had to.... and it does a great job of pulling my 12 foot fishing boat trailer....
No members online now.
