U-joint...??
patov6
July 2007 TOTM Winner!
Santiago, Chile, Southamerica
Hi!
I bought a Super Dutyford D60 for my Ranger, it has a flange for a 1330 U-Joint and my driveshaft is with 1310, which u-joint Part No do I need to use my Dana 60 with this driveshaft??
Thanks in advance,
Pato
95XL
Fulton, NY
7.3L Diesel
I'm not sure exactly what part no. you would need, but I know what the part you need is called. It's called a conversion joint, I had to buy one for when I swapped a D60 into the rear of my Ranger, and used the stock driveshaft. I would call your local driveline shop and tell them what sizes you're looking to convert to and from, and they should be able to piece something together for you (by piece together I mean, when I bought mine, they had a conversion joint that was the right width for the stock shaft, and the right width for the D60 pinion, but the caps on the pinion side were too big of diameter, so they grabbed some caps off a standard joint and put em on my conversion joint and sold it to me that way, instead of having to buy both joints and then just switch caps when I got home.)
Hope this helped?
oh, btw, I don't know if you'll have to or not, but I had to have the driveline shop shorten my driveshaft by about 3". Just something to lookout for.
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
a spicer 5-134x. the off brands also use the designation of 0134
TexasDuck66
July Truck of The Month
