trader007
- May 22, 2010
- 2
- Ford
i have to brag about this.
i bought my 99 4.0 4x4 ext cab ranger when it was 4 years old for $7500. it had 125k on it.
fast forward to now, and the body/motor has 223k miles. i did replace the tranny at 180k but why brag? no trouble codes. zero!
i had a check engine light with the bank 1/ bank2 lean code for about 50k miles. finally, my lower intake gaskets blew water so i did the job myself out in the parking lot of my apartment, with limited tools. all the work ever done to this truck has been by me (after 125k of course, but the guy i bought it from basically did nothing to it).
and MAN was that a SUCCESS. been a month now, and no check engine light and NO CODES what-so-ever. not on the main ecu, the powertrain ecu, the airbag ecu, and the ford electronic ecu (i have a ford specifc scanner, pulls over 2000 parameters off all the computers). not a single fault anywhere.
all i have left is my driver side torsion bar. its loose at the adjuster. those pads or whatever they are must be bought from ford and theyre $100 a side... so for now im dealing with a loose spring basically. otherwise, the truck runs and handles like new!
i want to post some pics when it hits 225K! the truck is rusting starting to look like shit, but mechanically underneath its very solid and sound! im starting to think i can put another 100K on it
things that i replaced over the years thats not normal maintenance (that i remember). no particular order
tranny
alternator
radiator
windshield
back window (slider kind)
both front bearings
abs speed sensor rear
ignition coil
every freakin ball joint in the front
exhaust
drain/replace rear end fluid
like 5 batteries until i got sick of it and went diehard platinum. took care of battery problems and then some! crazy good batteries.
and i think thats it! on the fly 4 wheel drive still engages perfectly! did the brakes once or twice of course... so there was quite a bit of work done, but i did it all myself and it was fun. its an easy truck to work on! and parts are mostly cheap!
tranny
alternator
radiator
windshield
both front bearings
ignition coil
exhaust
