corerftech
- Apr 22, 2021
- 84
- Memphis, TN
- Ford Ranger
Need some suggestions.
starting the 5.0 into 87 std cab and have determined a few things.
Batt box needs to go to bed.
Coolant/washer tank must go (or relocate/change format as applies),
Power steering pump needs to become remote Volvo electric.
I need space on both sides to have two TD04 Saab turbos mounted on forward facing manifolds.
On left I have an alternator on the EXP FEAD and is missing AC comp.
On right I have PS pump that will delete.
That leaves me with:
Clutch fan smooth pulley
Alternator
Tensioner and other pulley
I really need the alternator in a high position.
Water pump may become electric too. And maybe fan!
Unsure of where a Mustang alternator bracket mounts.
Suggestions?
Trying to avoid a single turbo as I still have to dump the PS pump to get manifolds pointed forward.
Anyone using GT40p cast headers switched left to right to get forward facing exits?
The Junkyard is the project store so there is no - “just buy this”, truck is a Frankenstein and that is the point of project.
Thanks in advance.
Alternator
Suggestions?
Thanks in advance.
