blbzeckhart
- Mar 18, 2021
- 8
- Age
- 47
- Mocksville, NC 27028
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
I'll give you the back story after I present the problem:
1994 4.0L OHV VIN X (overheated, milky oil)
Replacement engine from junkyard, out of the vehicle does not crank a full 360 when turning crankshaft with a socket and wrench. "Junkyard states is a good engine, 6 month warranty, and supposedely started before removal?
I didnt try to manually turn engine over via crankshaft prior to install.
So, uninstalling failed motor because of overheat, wont run condition. ON UNINSTALL, no problem manually turning crank to remove 4 torque converter nuts from studs, through starter hole.
Install Junkyard replacement Motor, cannot rotate crank all the way to get all torque converter nuts on. Initially thinking torque converter not in all the way, somehow engine to trans cock-eyed?, or engine has bent valves?
Unbolted engine to trans. Torque Converter seems in all the way? While separated, Engine will not crank 360, with flywheel attached? Is my junkyard motor bad, bent valves? with all 8 bolts in and tight with engine to trans, cannot get all 4 torque converter nuts on bolts. Now separated. Engine will not rotate 360?? I think bad engine from junkyard! Thoughts?
