Turn the key, sounds like a woodpecker...
Dabblingman
14
Seattle, WA
Ford Ranger (V6
*Sigh* This truck just keeps breaking down.
99 Ford Ranger. New battery last week. Went to start it just now. Instead of starting I hear a very quick drumroll/woodpecker noise. Taptaptaptaptaptap.
No other sounds. Anyone have any ideas?
Blmpkn
Toilet enthusiast
6,763
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Sounds like the starter solenoid is having a siezure...
Battery cables nice and tight?
Wouldn't hurt to check the battery voltage either.
superj
3,050
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
check the battery again
Ranger850
Doesn't get Sarcasm . . .
4,807
Tallahassee Florida
Stock 2"
Stock
Agree with "re-check battery" and/or all connections from Battery to starter. That "woodpeccker" sound it the tell tale sound of a bad/weak battery
alwaysFlOoReD
5,429
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Check battery. But most likely bad connection on the big cables. Check both -ve and +ve ends and under the insulation
Dabblingman
14
Seattle, WA
Ford Ranger (V6
My good friend came over with a battery charger, and had me hammer the starter and starter solenoid a couple times. And voila, it started up!
His belief is I have a short in the system somewhere. We will see. We are new owners, the other 222,000 miles are a mystery to me :)
Ranger850
4,807
Tallahassee Florida
Stock 2"
Stock
forgive us ALL for not mentioning the BFH method
ericbphoto
Overlander in development
TRS 25th Anniversary
17,211
Wellford, SC
6"
A "short in the system" would blow a fuse. You have a loose or dirty connection or a bad component. If beating on the starter made it start and all the wiring connections are clean and tight, then you need a starter. If tapping on the starter relay (mounted on the inner fender in the engine bay) made it start and all your connections are clean and tight, then you need a starter relay. Otherwise, check all connections, both positive and negative and make sure they are clean and tight and no corrosion (white/yellow/greenish colored powdery stuff) in the battery cables. Also, check battery voltage with a meter. A new battery, at rest, with engine not running should be about 12.6volts. If it gets much lower than 12volts, it won't work properly. If you check the battery voltage while someone is trying to crank the engine, it should not drop lower than 10volts while cranking. Immediately after starting the engine, voltage should be around 14volts. After running for 5-10 minutes, it should drop down to about 13.5 volts. If it stays at 14 or higher, it will "cook" the battery and ruin it - bad regulator. Replace regulator or whole alternator. If it doesn't maintain over 13 volts while running, the alternator is bad.
SenorNoob
726
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
^Info doesn't get any better than that.
To people who don't understand electricity everything is "a short". It drive me nut too. Had a shift supervisor tell me that one night last week. They had broken the plug in. Cut it off and replace and it worked great.
TexasDuck66
July Truck of The Month
