2.3L ('83-'97) Tune-Up: 1996 Ford Ranger XL
Ranger_XL
New member
16
Wind Gap, PA
Ranger XL
1996 Ford Ranger XL Regular Cab:
Engine: 2.3 I4 Lima,
Transmission: M5OD,
Drivetrain: 4×4 with Manual-Transfer Case and Manual-Locking Hubs,
Items: Spark Plugs (0.044 Gap, Motorcraft Single Platinum), Spark-Plug Wires (Motorcraft), Timing Belt (Motorcraft), Serpentine Belt (Motorcraft), Water Pump with Fan Clutch (Motorcraft), Air Filter (Motorcraft), Oil Filter (Motorcraft), Fuel Filter (Motorcraft), Oil (Mobil-1, Full Synthetic), and Antifreeze (Motorcraft).
What are your thoughts on addressing the camshaft-position sensor, crankshaft-position sensor, throttle-body sensor, idle-air control valve, and mass-flow sensor?
Mileage: 232,430
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
Blmpkn
Active member
80
Southern maine
Ford ranger
2.3
Mileage: 232,430
Are they bad? I wouldn't bother fixing what ain't broke, BUT if any of the mentioned sensors are massively easier to replace while doing the rest of your maintenance you might as well.
Ranger_XL
New member
16
Wind Gap, PA
Ranger XL
The one sensor that is bad or inoperable unequivocally is the fuel-sending unit; the fuel gauge never reads differently in spite of refueling.
Blmpkn
Active member
80
Southern maine
Ford ranger
2.3
I'd definitely change that lol, that would drive me nuts.
Blmpkn
Active member
80
Southern maine
Ford ranger
2.3
If they're not malfunctioning I wouldn't bother replacing them.
Mabey buy a can of maf cleaner and clean that, but yeah, no sense in replacing something that isn't broken.
Dirtman
Clam chowdah!
EMT / Paramedic
4,526
Over there --->
466.63 teaspoons.
So friggin big!
Give me money.
Clean the maf, and clean the IAC. There's zero reason to touch the other sensors unless they are bad. They are not "wear" items like spark plugs. They are simply either functional or not. The MAF and IAC do however get dirty and need to be cleaned periodically. (Use the proper MAF cleaner for the maf sensor, do not use carb cleaner, you can use anything on the IAC valve but coating safe throttle body cleaner is safest). While your cleaning, worth doing the throttle body. Again DO NOT USE CARB CLEANER! You have to use coating safe throttle body cleaner or you will destroy it.
