- Nov 7, 2019
- Reaction score
- 1,024
- Location
- sheep pen
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Automatic
- 2WD / 4WD
- 2WD
- My credo
- If it ain't broke, break it.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
So I did do it right. Now I'm out of ideas again
Somebody else told me it could be airflow restriction to an o2 sensor, maybe a clogged cat?It actually doesn't matter, as long as crank mark is at 12:00, cam mark can be at 6:00 or 12:00
6:00 would be TDC #1
12:00 would be TDC #5
If you are timing distributor or cam sensor at the same time, then yes, you would want cam mark at 6:00
Cam gear has twice as many teeth as crank gear, so if you time with cam mark at 12:00 and rotate crank one full turn cam mark will be at 6:00, and visa versa
So works fine either way
It takes three things for an engine to run.. Air Fuel and spark... make sure you have all three to start. Did you install a new timing chain? if so did you use the timing cover alignment tool? if you did and didn't use the tool be prepared for a major oil leak in the front seal... I know from personal experience.. if it doesn't leak you should play the lottery. you are one lucky dudeI been working on this truck for a little over 2 months now, since then I fixed the timing, replaces the Crank position sensor, fuel pump, full fluid change, and smaller fixes here and there. When I go to crank the truck up, it tries to start, and just won't, i have every sensor hooked up, all the fuses are good, battery is brand new, cables are all wired in, and the fuel pressure is good. Im thinking its mechanical, but my buddies say its electrical. Any ideas what it might be? Thanks in advance. Its a 91 4.0L 4X4
I just used a press tool on the crank pulley, if i start leaking, ill just have to realignIt takes three things for an engine to run.. Air Fuel and spark... make sure you have all three to start. Did you install a new timing chain? if so did you use the timing cover alignment tool? if you did and didn't use the tool be prepared for a major oil leak in the front seal... I know from personal experience.. if it doesn't leak you should play the lottery. you are one lucky dude
