Trouble installing front spring on 1996 4x4 Ranger - is a spring compressor needed?
sebastian323
24
Merced, CA, USA
Ranger XLT
Hello, I am installing a set of leveling springs (+1.5 inches) on my 1996 4x4 Ranger. I currently have managed to extract the old spring. However, I am having trouble slipping the new springs in. So far I have removed the shocks, the sway bar end links, the old coil spring, and the tie rod ball joints. Do I need a spring compressor to install the new springs, or can I remove more parts from the suspension and compress the spring with my car jack?
update: I successfully got the springs in. I used a combination of a spring compressor and having a friend step on the hub lockers to bring the control arm down. I used the spring compressor just to get the spring roughly in place, and then removed the compressors to fully install them.
Junk Collector
Truck of Month
4,789
Rapid City SD
I have someone stand on the lockout hub and push down as far as possible. That should easily give you enough room for a 1.5" lift spring... if you don't have a helper you could use a big pipe or something wedged between the frame and axle to push down while you slip the spring in.
sebastian323
24
Merced, CA, USA
Ranger XLT
okay . right now I am only one person so I may have to go the pipe route. I will give it a shot when I get home from work. You think a spring compressor will work as I do have that one one hand.
ericbphoto
Overlander in development
16,546
Wellford, SC
6"
Loosening the nut at the end of the radius arm might allow it to flex a little bit easier. But you should be able to get it with the ideas mentioned above.
sebastian323
24
Merced, CA, USA
Ranger XLT
I succesfully got the springs in. I used a combination of a spring compressor and having a friend step on the hub lockers to bring the control arm down. I used the spring compressor just to get the spring roughly in place, and then removed the compressors to fully install them.
