Trouble installing front spring on 1996 4x4 Ranger - is a spring compressor needed?
sebastian323
24
Merced, CA, USA
Ranger XLT
Hello, I am installing a set of leveling springs (+1.5 inches) on my 1996 4x4 Ranger. I currently have managed to extract the old spring. However, I am having trouble slipping the new springs in. So far I have removed the shocks, the sway bar end links, the old coil spring, and the tie rod ball joints. Do I need a spring compressor to install the new springs, or can I remove more parts from the suspension and compress the spring with my car jack?
update: I successfully got the springs in. I used a combination of a spring compressor and having a friend step on the hub lockers to bring the control arm down. I used the spring compressor just to get the spring roughly in place, and then removed the compressors to fully install them.
Junk Collector
Truck of Month
5,513
Rapid City SD
I have someone stand on the lockout hub and push down as far as possible. That should easily give you enough room for a 1.5" lift spring... if you don't have a helper you could use a big pipe or something wedged between the frame and axle to push down while you slip the spring in.
sebastian323
24
Merced, CA, USA
Ranger XLT
okay . right now I am only one person so I may have to go the pipe route. I will give it a shot when I get home from work. You think a spring compressor will work as I do have that one one hand.
Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
18,946
Wellford, SC
6"
Loosening the nut at the end of the radius arm might allow it to flex a little bit easier. But you should be able to get it with the ideas mentioned above.
sebastian323
24
Merced, CA, USA
Ranger XLT
I succesfully got the springs in. I used a combination of a spring compressor and having a friend step on the hub lockers to bring the control arm down. I used the spring compressor just to get the spring roughly in place, and then removed the compressors to fully install them.
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
