Natedog
- Aug 7, 2007
- 5
- CA
- Ranger
Greasyfingers,
Those wires on the fitting near the shifter are prolly for your reverse lights. Do your reverse lights work?
Your neutral safety switch (requires depressing the clutch pedal to crank/start the engine) is located on the top part of the clutch pedal (inside the truck cab) and is totally seperate part. Automatic transmission Rangers have a similar switch (located under the gear indicator on floor shift autos) that prevents engine crank/start in every gear except Neutral and Park. I eliminated this by iirc connecting the two wires under the dash.
