tri-y's on a 4x4?
ChrisR1S
10/2013 STOTM Winner
MTOTM Winner
Southern Virginia
Mild 5.0
Ok here's the deal guys. I'm ordering headers this weekend and I'd like to run shelby tri-y's. However I can't seem to find through my searching if anyone has ran or attempted to run a set on a 4x4. I'm sure the info is probably hiding somewhere but I can't seem to find it. I may end up being the test dummy :icon_welder:
So...anyone here know anything on this? I'm just worried of the front shaft possibly being in the way
baddad457
18
Opelousas La.
They don't hang down any lower than the engine or transmission if that helps.
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Maybe this will help?
This is a 2wd, with a T-5 trans. Possible help with the guessing...
My crossmember is about 3" forward of the stock location.
The big washers are the end (rear) of the 2wd radius arms.
The O2 holes were drilled by me, so they won't necessarily be an issue.
I'm curious to hear the answer, it's something I hadn't thought about.
ChrisR1S
MTOTM Winner
Southern Virginia
Mild 5.0
Thanks for the info guys. An I forgot all about you having run Tri-y's Teddyzee. From the pics it looks like they SHOULD work being as they hug close to the trans and don't go too far back. I love the wealth of pictures from your build! How's the coating on the headers holding up?
superdave1984
24
KY
From what research I have done, tri-y's fit very well unless you have an AOD transmission. And yes, of course I bought tri-y's before I found this out.
baddad457
18
Opelousas La.
As with most parts in a swap.............if it don't fit...........modify it.
ChrisR1S
MTOTM Winner
Southern Virginia
Mild 5.0
Very True. However if im going to dish out the cash for coated headers id PREFER not to get to cutting and whatnot lol
baddad457
18
Opelousas La.
Get em plain, modifiy em, then have em coated.
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
Mine are chrome.
Since they cannot even really be seen once they're in the truck, I have no idea how they're holding up!
But they looked good on the engine stand!
Good luck with it.
COPPERHEAD85
41
west tennessee
302
Looks like the Drivers side is heading right for the T-Case.
1mean02hd
Chase, MD
5.0L V8
I was wondering the same thing. I have the Tri-Ys on my 94 2wd, but I have a 95 4x4 I'm starting on. Seems like most guys that do the 4x4 swap run the Exploder motor and just use the manifolds/ headers from that. Take pics when you fit them so everyone else can see.
