Transmission Swap Help
Rogueingtin
So I did a auto to manual trans swap. The manual trans is from an 01 my truck is a 99. I adapted the 99s wiring harness to plug in with the manual. I also Swapped in the ecu from the 01. After all this the truck doesn't try to start at all. If anyone knows away to solve this it would be greatly appreciated.
Both trucks are the 3.0 engine.
01 trans is the M50D
99 trans is the 5r44e
All other electrics seem to be working
The 01 computer had PATS. The security system is holding up the show.
forzainformer2
Put the original ecm in the truck, im not a ranger expert but if it has the same pats system as a 99-03 f150 then you need the original ecm
forzainformer2
The ecm swap you've done has messed up the whole project, get the original ecm back in
8,370
In 2001 the Ranger computer will have PATS inside, Type E
1999 Ranger had Type B with separate PATS module that was "married" to the computer(PCM).
Around the ignition key slot is an antenna, called the transceiver.
When key is turned on the PATS transceiver sends a Radio wave out, this wave gives the PATS key just enough Power to send out its Unique Code number.
The transceiver picks that up and PATS compares that unique number to the numbers it has in memory, the 2 or 3 keys programmed in at the factory.
If number matches then starter motor can work, also Fuel Pump and Fuel injectors will work.
If there is no number or no match, then no starter motor and no fuel pump or fuel injectors.
There is no By-Pass for PATS, you can send out 2001 computer to a programmer and he can delete PATS, so any key can start engine.
A mobile Locksmith with Ford software can come out and add your 1999 keys to the 2001 PATS memory.
Above the glove box is the 1999 PATS module, it will need to be removed, its wiring goes to Transceiver, and starter relay, also computer.
You need to change it for Computer only PATS hook up.
You could swap out Key cylinders and use the 2001 Keys, door keys would be different unless you swapped those out.
Wiring Diagrams are below
Rogueingtin
So we tried the 99 ecu as well and it's still not starting could the neutral safety be a part of that?
8,370
Yes, only its a Clutch switch on a manual trans setup.
All vehicles are wired as Manual, there is a Clutch switch plug where the clutch pedal would be.
If vehicle is an automatic they added another wiring harness that plugs into clutch switch connector, it runs down the transmission and plugs into the DTR sensor, digital transmission ranger sensor
So you should have unplugged that extension wire, and plugged in the Clutch switch that is on the pushrod.
Drawing of it here: https://ww2-secure.justanswer.com/uploads/scottz136/2010-02-11_000105_1111.gif
In the engine fuse box is the Starter Motor Relay
When you turn the key to START the ignition switch sends 12volts to the clutch switch
If clutch pedal is down all the way the switch is closed and that 12v is sent to Starter Relay, but..........................
The PATS Grounds the Starter Relay, so even it relay gets the 12volts it still won't close unless it is Grounded.
When this Starter Relay closes it sends 12v to the "other" starter relay/solenoid on the stater motor which will activate it
I posted a 1999 starter circuit diagram in this thread: http://www.therangerstation.com/forums/showthread.php?t=170877
