Transmission noise
Muooman
az
ford ranger 4x4
Hello all and thanks in advance. I have a 99 Ford ranger 4x4 3.0 with a manual transmission with 165,000 miles and its making a whining noise in neutral and with the clutch in or out it does not change. Even happens when i am driving don't matter the gear. At first i thought it was the water pump bearing as it sounded like it was coming from the front but after a water pump change and we had it up in the air the noise was really load. So we took a stethoscope to the transmission and there was the noise load and clear. Anyone else have the same problem and what part in the transmission was it. Thanks again
Bronc3
ASE Certified Tech
23
Zero Gulch, Floriduh
Supercab FX4
3"
Only thing I can think of that wouldn't change much possibly would be the throwout bearing, but even that should change a little when on and off of the clutch. Mainshaft bearings would be quiet sitting still in gear.
