Transfer Case Leak
PaulZ
50
Been awhile since I've posted but I LOVE my Ranger. '99 is leaking between the transfer case and the round dingus (I cleaned it before the photo, it actually runs forward to the case joint). What's up there? I wouldn't care except I just installed pavers in the driveway.
Thanks!
46154
Junk Collector
Truck of Month
4,797
Rapid City SD
Drain plug. Pull the round dingus off and see if you can tighten it a bit - or drain it and refill with ATF, and use a little teflon tape on the plug.
PaulZ
50
Excellent! Was hoping for something simple, I could use the break.
Thanks Man!
Two things:
1) Remember to get the FILL plug out before messing with the drain plug.
2) These are iron pipe plugs, they are tapered, covered with a thread sealers and sunk into an aluminum case. Don't just try to tighten it. Go get a replacement and don't over tighten it. You can crack the case open. Then it will leak more.
PaulZ
50
Thanks guys, mission accomplished. That was the leak alright.
No members online now.
